Check if your memory is full either phone memory or your memory card and check if where your recorded video will be stored after recording. either the phone memory or memory card if any of them is already low in memory space you really can't start video recording if you don't have enough memory for you to store the video you want to record..Hope it will help you.
that means your camcorder is set to record on the disc not on the memory card. try to look on the settings on your camcorder there's an option fo you to choose like disc or memory card to be use as recording. hope that helps!
You can record video with audio onto the Memory Card. Follow the instructions below.
Recording moving pictures onto a MEMORY CARD
1. Insert a Memory Card into the slot on the camcorder.
2. Set the mode switch to MEMORY CARD position.
3. Set the power switch to CAMERA mode.
4. Press the START/STOP button, the images are recorded on the MEMORY CARD in MPEG4.
* You can record 10 ~ 20 seconds continuously.
* You can record a still image on the Memory Card by pressing the Photo button instead of the START/STOP button.
5. Press the START/STOP button to stop the recording.
Notes:
* Moving images that you recorded are saved in *.asf file format on the Memory Card.
* The moving picture images on a Memory Card are smaller size and lower definition than those on a Tape.
* The sound is recorded in mono.
* The following functions cannot be operated in M.REC Mode. - DIS (Digital Image Stabilizer), Digital Zoom, Fade, Program AE, Digital Special Effect, Slow Shutter.
* Don't insert or eject a tape during Memory card recording as it may record noise.
* Don't eject the Memory Card during recording as it may break the data on the Memory Card or the Memory Card itself.
To achieve MPEG2 video performance, large amounts of data must be written to the SD Memory Card in real time. The read and write speed of the SD Memory Card may differ from manufacturer to manufacturer, so we recommend using Panasonic SD Memory Cards with the high-speed transmission rate of 10MB per second (SD Memory Cards that are 256MB* or higher have a transmission rate of 10MB per second).
FINE Mode recording (High image quality 704 x 480 pixels) recording requires an SD Memory Card that is 256MB* or higher.
NORM Mode recording (Normal image quality 352 x 480 pixels) recording requires an SD Memory Card that is 32MB* or higher.
*Usable capacity will be less.
The use of SD Memory Cards other than the ones mentioned above may result in the following error message: [This card cannot record in MPEG2 mode.]
This error message indicates that the memory card cannot be used to take videos. Change the storage location to internal memory. Use the memory card to store pictures
This error message indicates that the memory card cannot be used to take videos. Change the storage location to internal memory. Use the memory card to store pictures.
