The washer goes through the washing cycle fine. Then, when refilling for the rinse cycle, the water will not fill up - it keeps running. Or, the water begins to fill up and then drains out with the water continually running. The water is not staying in the tub for the rinse cycle. We are losing several gallons of water each washing cycle and having to stay with the washer each time.
It sounds like a siphon issue.
Check
that the drain hose does a high loop before it goes into the drain
pipe. (ie. drain hose loops above the water level inside the tub). Make
sure the drain hose is not pushed too far down into the drain pipe.
Also if the drain hose is sealed to the drain pipe this will create an
airlock and a siphon will occur, allow air to enter between drain hose
and drain pipe connection.
This should help you but if there is still a problem let me know and I'll try to assist you further.
Guru, You are our new hero! We just needed to talk to the right person and YOU ARE DA MAN!!!!!!!
