Televison & Video Logo
Anonymous Posted on Jun 01, 2013
Panasonic hdtv 1080i picture bright
My Panasonic HDTV 1080i has been giving me a really bright picture where the colors are so faded, it's hard to see the picture. I just replaced the bulb with a new one, and NOTHING has changed. I've tried to adjust the color settings on the TV but that doesn't change anything either. I thought it was the video cords, but when I hook up my Xbox or DVD player, it's the same faded brightness. I know it's the TV, I just don't know what it is. Someone help me!!!!
Anonymous
Level 2:
New Friend:
  • Expert 60 Answers
  • Posted on Jun 03, 2013
Anonymous
Expert
Level 2:
New Friend:
Answers
60
Questions
0
Helped
4713
Points
116
It could be your main board going bad.
1 Related Answer
Anonymous
  • 375 Answers
  • Posted on Aug 23, 2008
SOURCE: Panosonic 50" LCD 1080i HDTV screen picture faded
try setting your menu;s to adjust the picture settings
I have a panasonic pt-61hx42 tv and the picture is dark and hard to see night sceens Is there another bulb besides the three colored bulbs
have you already check in the menu adjustment with the brightness,how about cleaning of the reflector inside doesn't work?
What is the picture quality setting for a panasonic 1080i HDTV
Adjust the video output settings on the devices connected to your Panasonic HDTV. To view 1080p programming, enter into the service menu on your external device and change "Video Output" to the appropriate resolution. By default, the Panasonic TV is always displaying content in the resolution provided for it by the external device. If your cable box is set to output in "1080i," for example, your TV will display content in 1080i.
Let me know if this fixes the issue.
Regards,Suhail
My picture faded off the screen
Need to see if you're getting high voltage. See if you have 130v dc on the collector of the horizontal output transistor.
2helpful
Convergence panasonic HDTV 1080i bbe hi definition
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Even with a new panasonic bulb;the picture is not as bright as when it was new.prob?
We replaced the lamp on our pr61lcx65 rear projector panasonic tv. We still have colorful spots and now it is getting darker and have yellow on bright picture and red on dark picture running through it. Please help.
2helpful
Blury screen on panasonic 1080i hdtv
seeing double and a lot of green on my panisonic hdtv 1080i what do i need to replace?
My picture is dark and have changed the brightness
Hello!
Well it seems that your lamp is about to go out, replacing the lamp might jus do it ! Also make sure you get a Philips lamps, they work like a charm.
And regarding the long plastic cover just be a little bity patient and you'll make it come off, just make sure you do remove all the screws.
This model is notorious for needing a new lamp about every 2 years. The lamp is accessed through the front by removing the long plastic cover under the screen (it just pulls off). Under that, to the left of center, is a square cover with one grey plastic screw. Loosen the screw and pull the lamp assembly out. It should just slide right out. Turn it around and look at the lamp. If the lamp face or reflector looks "cloudy" or "misty". Replace the lamp with Philips part number TY-LA1000. Just Google the number and you will find them available for around $100
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
