Problem: When I turn the machine on as it begins to warm up after about 10 seconds it shuts down and I get an L6 code. I Turn the machine off and wait 5 seconds, turn machine back on, the copy bar (with the green light)turns on but only moves (jerks) back and forth about 1/2 inch repeatedly for about 1 minute while the machine is warming up then it shuts down and I get an E7 code
which suggests possible the faulty door lock has been fitted with another faulty door lock. this has happened to me on two or three occasions in different situations.
I says power cut restarting in 10 seconds
I'm sorry, it is the board, the switch mode power supply is dying.
Every time it starts to do something it power cuts.
Best to get a new motor controller board,
Quote the 6 digit part number under the bar code to get the right part.
its similar to the problem that with the laptop that get warm and shut down, the chip inside get warm and then it shuts down
its not worth to fix this problem
sorry for not been able to help
The gas turns on and off repeatedly all during the drying process. You could have a weak flame sensor. Sometimes these dudes take longer to cool down and regain continuity with age. Seen it.
Usually that means the polygon motor isn't up to speed.
Try turning the copier off, wait 20 seconds, and turn the power back on.
Is there any other devices plugged into this electrical outlet?
Sounds like you have a bad green picture tube that has failed. To check this out; remove front speaker grill, remove small panel, you will see three CRT's (pictue tubes) sticking down, remove the little board on the middle tube then restore power. If TV stays on more then likely the CRT is bad but not always the driver on board could also be bad, check voltages.
Hi this could means that you may need to replace the washing machine bearings. Once the bearings are bad, the motor overheats and it will automatically shut down after the first rinse.
