Everything else seems to function properly, the machine seems to cycle completly, however the water is cold.
Model # 110.26842691
Kenmore 80 series
top-load Washer
Hi
Thanks for using FixYa. If the cycle doesn't
complete, then the first thing that should be checked is the Timer and then the
heating element. Timers don't often fail. But if every other part of the
dishwasher seems to be working properly and the timer knob seems to be stuck in
one place--doing one function continuously--the timer may be at fault.
Dishwasher timers can't be repaired. If yours is defective, replace it. Many
dishwashers heat the wash and/or rinse water to a higher temperature, as the
cycle calls for it. In these cycles, the dishwasher pauses after it has filled
with water, waiting for the water to reach the pre-set temperature. What
happens next depends, as follows: On some units, the pause is timed and the
unit continues after the allotted time. On others, the cycle can't continue
until the water reaches the higher temperature. If you have this type of
dishwasher and the water isn't being heated (say, because of a problem with the
heating element or thermostat), after the unit stops at the heating cycle, it
never continues. When you repair the heating-system problem, the "cycle
problem" is fixed too. Please accept the solution if the
issue is resolved or post a comment for further assistance.
Thanks
Rylee
