Ever since i upgraded my Dlink Dir-655 router to the latest firmware (at that time, FW: 1.35EU), when i'm trying to access a webpage that isn't available, AKA http code 404, or whneever my internet connection is down, my router shows me a custom 404 page stating that the page isn't available or my internet connection might be down. This wouldn't be all that big of a problem if it would do it properly and send me the 404 header along with the custom error page. I was wondering if there is a way to disable this custom error page on the router somehow and let the browser handle things the proper way as it should in the first place?
Um, no offense, but did you even read my message before posting that reply? I'm not having connection issues. There is nothing wrong with the wifi, or with the router's connection to the internet.
My problem is that, when I try to go to a URL that does not exist, e.g. http://no.such.url, instead of seeing a 'Could not find the sever specified' page, I get redirected to http://dlinkrouter/error-404.htm.
I'm confident that this issue is cause by the router, not by the ISP, since it is redirecting to a page served by the router itself.
for more help visit CBR Tech Solutions
SOURCE: Dlink DIR-655 not accessable after 24 hours
U have to tell me whether u have to unplug machines or the router
If that's the case dhcp for ur router is assigned from some other place. Weird. U have to enable dhcp of ur router. Don't allow running another dhcp from ur local systems only if it is a must. WHEN U CONFIGURE THE ROUTER'S DHCP, MAKE SURE TO SET THE LEASE TO A MAXIMUM VALUE SO THAT IT WANT CHANGE THE IP ADDRESSES FOR MACHINES.
If u assign static ips u have assign the dns and also the default gateway
Type ipconfig /all in a comand prompt and check the settings and set appropriately
Remember, don't allow any other source to assign dhcp for the router.
If this solution works for U please rate the answer
Thanks
Best of Luck
SOURCE: I have a DLink Dir-655 router. It seems drop a lot.
The Position of the router need to relocated and placed such that it has minimum shields to the devices. It may not be providing enough signal strength to break through the obstacles on its way. I will suggest you place it high. This way the device will have minimal obstacles to the router.
SOURCE: I bought a D-Link DIR-655 router 2 days ago &
reset your router again and run the wizard for the configuration.
Testimonial: "Big Thanks Cyber! I was so frustrated but the simplicity of your advice was all it took for me to resolve my dir-655 router issue... I'm very grateful"
SOURCE: Can't connect XBOX 360 S to D-Link DIR-600 Router
For instructions on setting up the PS3, Xbox, or Wii, for awireless/Internet connection. please click on this link :-http://fixhomenetwork.com/xbox-play-station-wii.php
Testimonial: "Although I solved the problem by other means, the link provided seems to be extremely useful for others who may be experiencing the same issue with (maybe) other routers or even for different reasons. Thumbs up!"
Press and hold the RESET button at the back of the router with the power ON until the LEDs flash at the time the release the RESET button. (firmware version was 3.00, and upgraded to 3.05) Connect a LAN cable from the D-Link to your laptop/computer's LAN port, open the browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
