Hold down the Windows key (Windows icon) and press "X". Select "Control Panel" in the menu.
Step 2: Locate Your Network Connections
In Control Panel click "View Network Status and Tasks". This will take you to the "Network and Sharing Center".
Now in "Network and Sharing Center" select "Change Adapter Settings". This will take you to your "Network Connection".
Step 3: Open the Properties of Your Wi-Fi Adapter
Right click the adapter that is connected (or going to be connected) to AirOrangeX and select "Properties".
Step 3: Disable Connection Sharing
In the adapter's Wi-Fi Properties select the "Sharing" tab.
Be sure that the check box indicated is NOT check and press "OK".
Internet connection sharing window
You have now disabled internet connection sharing
Computer network is many computers connected together either wireless or through cables. It enables sharing of data and transmitting information with the different computers. Infobytes, one of the leading IT networking companies in Dubai offer top rated IT solutions.
Go at control panel (if you use windows 7), Network and Internet , Network and sharing center.Check where it says "View your active networks" , under the network you are using it will say Home network or Work network. Click that and change it into Public network.Voila, network sharing center has disappeared!
