SOURCE: os system not loaded! hard drive was totally formated. PA800
Hi, have you solved this problem yet? If you have, share the solution with us please! :)
SOURCE: I have a old (but almost unused) Korg d1200
First thing would be to check the power supply voltages. It may be the disk drive is failing. Drives are inexpensive, might be worth a try with a new drive. Also check that cables to the drive have not been loosend by handling.
SOURCE: Hello, I have a big
It will require repair. I suspect by you description that the D-A convertor has failed. This is a chip that is far beyond a DIY project to change. Do further testing to make sure the power supply voltages are correct and that headphone output sounds the same problem.
Here is your service manual: http://elektrotanya.com/korg_pa800_sm.pdf/download.html
Scroll down to "get manual" and click to download the manual. IGNORE other download links.
