Dell Inspiron 1720 Notebook Logo
Posted on Mar 21, 2009
My dell inspiron 1720 does not turn off automatic with windows XP
  • rlp4000 Mar 21, 2009
    laptop will not power (off winXP sp3) normal mode, safe mode or CAD
    dell 1720
Dell inspiron 1720 vista admin password recovery?
If you are running Windows 7, if you type in the wrong password once, it normally says reset password... below the box for the password. Insert a removable disk (such as USB, floppy disk, etc.)
and follow the prompts.
I have left and right handed dell a215 speakers but don't know how to connect them
you might need a usb to speaker adapterhttp://www.ebay.com.au/itm/USB-2-0-MIC-Speaker-5-1-Audio-Sound-Card-Adapter-/120645945426?pt=AU_Laptop_Accessories&hash=item1c170f0852
hope this help
Dell inspiron 1720 keeps dropping into standby mode when running any application using windows XP
Make use of some antivirus! Or it may because that your internal memory is full...
My dell inspiron 1720 hdd password forgot
send me hdd hash code .. turn on laptop u will se a code .. ****4232343-595b or somthing else .. send me that ill send u master password..
Spilt drink on inspiron 1720. after letting dry
Make sure you DO NOT plug in your lap top to the power out let. This could cause a shock.
You see the Dell media direct, means your CMOS is OK.
But if Windows is not loading means the spill could have damaged your hard drive. I would strongly suggest you take it to a shop where they repair laptops.
This way you may have to replace your hard drive, but save your note book.
Dell 1720 screen
If you can see the vertical lines during POST, try to check the vertical lines in BIOS. If the vertical lines are there in BIOS, the only thing you can do is to replace your LCD screen.
I get a black screen with the mouse everytime i boot to windows
Is it black all the time? From when you start your computer to when you turn it off?
Sounds like the backlight is bad.
1helpful
My dell inspiron 1720 laptop webcam doesn't work for most programs including msn skype dell webcam manager it said that it can not find my webcam but the webcam only works for yahoo messenger
you can have the webcam workin for only ne application at a point in time also check to see that you have activated the webcam access on the other applications and this time try with the windows firewall and other firewalls deactivated
Suddenly no sound on my dell inspiron 1720, vista, sigmatel
COPY UR IMP DATA O OTHER DRIVES AND FORMAT UR WINDOWS.
BEST SOLUTION.
AND DONT INSTALL UPDATES
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
