I have a brand new Troy-Bilt XP Horse, model 13bx79kt011. The mower starts up fine, the blades spin fine. But the mower won't actually move, neither forward or reverse. I have the hydrostatic transmission bypass pushed in, which according to manual is to engage it. The mower just doesn't move. It appears the mechanics of the speed lever work (it moves). I think the mower works fine, I am just missing something stupid. Any ideas?
SOURCE: HYDROSTATIC TRANSMISSION NOT WORKING ON NEW MOWER
there is a rod on the rear of the mower that is pulled back and lock into place this is there to push the mower around when not running it just lift the lever up and it should pull in then your ready to go
SOURCE: Riding only on an old
Depending on which Craftsman riding mower you own, there are a number of problems that could cause the mower to no longer move:
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
SOURCE: Mower will not move.
It is very likely that your belt is not on right. Check your manual to see it it is on right.
SOURCE: I have a cub cadet model 1420 with hydrostatic
i had exmark hydros i was told to never wash them, the water does more damage than good. have you checked or changed your hydostatic oil and filter latley? if you have, when doing that you have to be very careful not to get any foriegn objects in the oil resevoir, dirt, grass clipings, anything will ruin the hydro pump.
SOURCE: hydrostatic lawnmower doesn'i want to move
There will not be any actual adjust in the unit, there will be some adjustment in the rods from the hand/foot lever, if you can see the arm moving freely on the unit when you work the foot/hand lever it is probably not a linkage problem, if there is an external brake disc, make sure the brake is not binding, finally somewhere on the unit will be a bypass lever for push mode, make sure this has not been engaged.
