The TV will be working fine and then it shuts off by itself. I unplug the power cord and leave it alone for a while, the longer the better, then plug it back and it will turn on by itself. It will then stay on, sometimes longer and sometimes shorter times. I hear some clicking, the same sound as when the TV is turned on like a relay or something and it shuts off. The TV was made in 1996 and I had it repaired after it would not turn on. The TV worked fine after the repair for about a year then the trouble started. Instead of sending to be repaired again I just bought another one but still use this one until I get tired of unpluging and pluging it back. It has a good picture and works fine until it shuts itself off.
SOURCE: JVC AV-36950 TURNS OFF
Replace C953 1000mf / 35v in power supply....capacitor
top will appear slightly bulged or will check bad with
ESR meter...........................T.
SOURCE: JVC TV crisis.....HELP
yes... i actually work at verizon the tv is to old for fios because fios is so advanced we run off ot 720 to 1080 depending on areas. what kind of box is it? is it the hd box or stb>
SOURCE: JVC AV-36260 No Sound No Picture Red Light Blinks Copntinuously
Try this blog I found on this site. I have the same model and problem with my JVC TV set and I was able to fix it for 2 bucks at home by myself.
Good Luck...Kim
http://brentlavelle.blogspot.com/2007/12/i-fixed-my-jvc-av-36980.html
SOURCE: Turns off randomly
mine does also does yours click at random times and the screen goes out in small places for a split second?
