Your best investment is a Haynes Repair Manual, either from your local Auto Zone or similiar retailer or online: http://www.haynes.com/products/searchType/vehicleApplicationSearch2/searchEnd/yes/sfID1//sfID2//sfID3//year/1997/make/Honda/model/Accord/x/20/y/3/productID/193. Step by step instructions on troubleshooting, repair or replacement, based on a complete teardown and rebuild.
SOURCE: 1995 nissan pulsar wont run properly
What your smelling fuel for is the fact that once you start it your flooding the **** out of it.. your fuel relese valve needs to be closed up a bit, your intake for fuel is to high basically, this can and will happen due to racing, vibration, or just over time. Its one of those problems that occurs now and then, it is a simple fix!!
SOURCE: my avenger cuts off after being driven for at least 5-30 minutes
a very common problem with these cars is the crankshaft position sensor. also camshaft position sensor. they will make the car do exactly what you described. let me know what you find
SOURCE: poulan micro xxv wich will run for 5 mins then flood but why?
clean out the vents on your fuel cap. you may also have sawdust or dirt stuck on the diaphragm in the carburator
SOURCE: flooding
Yes its getting too much petrol , you will have to check the float pin, better to clean the carb.
