I have this malfunction code, C-0510, coming up on my Konica/Minolta Bizhub C350 copier/printer. Anyone know what it is? I don't use the techs, because they charge s stinking much just for their monthly fees, and I don't pay for the service anymore-seems like most things should be able to be fixed by the owner. Last time I had an error code and it stopped working, the guy came out and sprayed it with air and it worked again. Tried it, but it didn't work. Anyone know the codes?
I have this malfunction code, C-11A3, coming up on my Konica/Minolta Bizhub 350 copier/printer. Anyone know what it is? I don't use the techs, because they charge much I don't pay for the service anymore-seems like most things should be able to be fixed by the owner. I needed help for this code
The error codes 3aa1 its your elevate trays on the finisher
Look at each tray in the right back corner you might have some paper stuck behind the tray. If so remove it then do a trouble resset and see if it fixes your problems. Most of the time I have seen that error is been when they have filled the paper tray with to much paper and it shoot off the guide and jams its self behind the paper tray.
SOURCE: c350 malfunction code c-0501
After replacing the fuser unit, if you got a c0501 code you must open the front door where the toner is. On the right side (hinge side) next to the black toner and drum unit there is a plastic pannel/cover. In the lower portion of that pannel there is a hole where a trouble reset switch is loacted. With a flashlight you may be able to see it. You are ment to use a thin screw driver or the like to push the button. You do this while the machein is on and desplaying the code. As soon as you press the button the copier will clear the code and start warming up. Thats it! If you are un certin of the button placement you can take out three screws from the pannel and loosen one screw from the pannel above it and and pull the pannel off the unit. You will see the board and it is the button on the (left), as there are two of them. Tho you only have access to the one thru the cover.
SOURCE: copier malfunction
Code C0F36 is a low toner density error on the black developing unit.
Was it asking for black toner before this code appeared?
