SOURCE: another inlet / drain light cycle interruption problem!
When the water stops too soon, it could be the "over flow" is stuck in the downward position, therefore the dishwasher thinks it's going to over flow. Check that out. Otherwise I'm afraid this sounds like the circuit board is shot.
Miss Midget
SOURCE: New World DW60 dishwasher not
I f you have warranty on this please call them, you have a defective D/W.Unless there is no charge for repairs ,don't spend a dollar on what is going to be a on going problem ahead.To explain how to fix this is what the manufacturer should have done in the factory and not made 1 dollar off of this defective D/W until it proved this to be ready .What has happened to Quality Control ? Does it no longer matter ? Very sorry ,you should seek a refund ASAP.
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
SOURCE: ie error code
The Water Supply Tap is closed.
The Water Supply is shut off.
The Inlet Hose is kinked.
The Water Pressure is very low.
(below 10 psi)
Inlet Valve is OK?
The filter of Inlet Valve is clogged
by impure water.
The Hall sensor is OK?
The Impeller of Air Guide is bound
Measure the electric resistance of
Inlet Valve. (950-1300 )
Clean the filter of Inlet Valve.
Check the frequency of Inlet Water
by the Test Mode.
Replace the Air Braker.
