Exercise & Fitness Logo
Posted on May 30, 2013
Honda fit 2009
More fuel condumption
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on May 30, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
547
Points
29
Fuel efficiency is a form of thermal efficiency, meaning the efficiency of a process that converts chemical potential energy contained in a carrier fuel into kinetic energy or work. Overall fuel efficiency may vary per device, which in turn may vary per application fuel efficiency, especially fossil fuel power plants or industries dealing with combustion, such as ammonia production during the Haber process.
In the context of transport, fuel economy is the energy efficiency of a particular vehicle, and is given as a ratio of distance travelled per unit of fuel consumed. Fuel economy is expressed in miles per gallon (mpg) in the USA and usually also in the UK-there is sometimes confusion as the imperial gallon is 20% larger than the US gallon so that mpg values are not directly comparable. In countries using the metric system fuel economy is stated in kilometres per litre (km/L) in the Netherlands, Denmark and in several Latin American or Asian countries such as India, Japan, South Korea, or as the reciprocal ratio, "fuel consumption" in liters per 100kilometers (L/100 km) in much of Europe, Canada, New Zealand and Australia. Litres per mil are used in Norway and Sweden.
Fuel consumption is a more accurate measure of a vehicle's performance because it is a linear relationship while fuel economy leads to distortions in efficiency improvements.
Weight-specific efficiency (efficiency per unit weight) may be stated for freight, and passenger-specific efficiency (vehicle efficiency per passenger).
2helpful
Where is the fuel filter on a 2009 Honda Fit Sport?
Sadly, the filter for this car is located in the fuel tank. Before going to the trouble to try to replace it (and it may come to that) it might be worth replacing spark plugs and ensuring that all vacuum hoses are connected, tight, and not leaking.
Can't get driver door to lock 2009 Honda Fit and romote key not workin correctly
Something broke inside door probably lock linkage rod inside door panel needs to be disassembled
2answers
Fuel pump relay on 2009 honda fit
honda fit. 09
the operators guide show the fuse boxes and usually relay names inside. look there yet? that is always first ofter checking for bad fuses
no symptoms posted, so cant guess, job or reason or whats up./
alldata.com
i looked but all 20 pages of fuel system have no name.
just page 1 to 20
too lazy to read them all.
I need the to know which fuse goes to What in my Honda fit 2008
PGM-FI main relay 1 (FI MAIN) is energized whenever the ignition switch is ON (II) to supply battery voltage to the ECM/PCM, power to the injectors, and power for PGM-FI main relay 2 (FUEL PUMP). PGM-FI main relay 2 (FUEL PUMP) is energized to supply power to the fuel pump for 2 seconds when the ignition switch is turned ON (II), and when the engine is cranking or running.
1helpful
STRIPPED SPARK PLUG ON MOTOR HEAD ON 2009 HONDA FIT SPORT - HOW TO REPAIR
check with any napa autoparts store they have a thing called a helecoil that will cure your problem and they will show you how to use it ,if this was helpful plaese chech the box below
Seeking replacement manual for 2009 Honda Fit
Go to helm.com. on upper left, click AMERICAN HONDA, then HONDA, thne punch in year, model, and what manual you want, click to cart, ect.
Top Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
