Music Logo
A
Anonymous Posted on May 30, 2013
How can i have dual voice on x5d korg? I lke piano and strings
Please help i want to enjoy my x5d korg. How can i have dual voice on x5d korg? I like piano and strings at the same time
tommibg
Level 2:
Sergeant:
Novelist:
  • Music Expert 126 Answers
  • Posted on Sep 06, 2015
tommibg
Music Expert
Level 2:
Sergeant:
Novelist:
Answers
126
Questions
0
Helped
69036
Points
521
Just go to COMBI mode.
how can i have dual voice on x5d korg? I lke piano - dual-voice-x5d-korg-lke-piano-strings-v3bkdlfzxxldunukh1pdnvp1-3-0.jpg
Press PAGE+. The display may look like this :
how can i have dual voice on x5d korg? I lke piano - dual-voice-x5d-korg-lke-piano-strings-v3bkdlfzxxldunukh1pdnvp1-3-3.jpgkdlfzxxldunukh1pdnvp1-3-3.jpg" alt="dual-voice-x5d-korg-lke-piano-strings-v3bkdlfzxxldunukh1pdnvp1-3-3.jpg" class="h_mi" />
In the example above, A03 and A49 is a sound PROGRAM number.
OFF and OFF is a Layer 3 and 4, were not activated.
So in our example, we only activate two voices (two layers).
X5D can combine up to 8 voice. To view the Layer 5-8, press PAGE +.
To change the sound of your choice, move the cursohow can i have dual voice on x5d korg? I lke piano - dual-voice-x5d-korg-lke-piano-strings-v3bkdlfzxxldunukh1pdnvp1-3-6.jpgoads/images/dual-voice-x5d-korg-lke-piano-strings-v3bkdlfzxxldunukh1pdnvp1-3-6.jpg" alt="dual-voice-x5d-korg-lke-piano-strings-v3bkdlfzxxldunukh1pdnvp1-3-6.jpg" class="h_mi" />
then change the value with the slider / value key (YES and NO):
You can also set the level of each layer.
Press PAGE + until a menu appears LEVEL.
Move the cursor and sets its value
5 Related Answers
Anonymous
  • 17 Answers
  • Posted on Feb 02, 2009
SOURCE: korg c-56 struck by lightning.
if your keyboard has been affected by a lightning strike then every semicondutor ( diode transistor i/c ) will be blown ...I know most components are on the mother board but not all ...I reckon cheaper to buy a new one ...sorry
Fred Yearian
  • 5603 Answers
  • Posted on Aug 29, 2009
SOURCE: Need help connecting Korg C-303 (Concert Piano)
Assuming the C-303 has a MIDI out, connect a MIDI cable from the MIDI output of the C-303 to the MIDI input of the symphony module.
Connect two audio cables (mono 1/4 inch) from the symphony module to a suitable audio amplification system OR possibly into auxilary audio input jacks of the C-303, if they exist.
I have a Symphony module but not the piano you have and I have mine connected to a Yamaha organ.
Fred Yearian
  • 5603 Answers
  • Posted on Sep 17, 2009
SOURCE: Kurzweil digital piano unpredictable voices and volume
The contacts of various switches and keys are likely dirty. They are often conductive rubber and need cleaning with 99% isoprophly alcohol and q-tip. Clean both the conductive rubber pill and th circuit board traces they contact.
Anonymous
  • 167 Answers
  • Posted on Nov 18, 2010
SOURCE: Hi. My Korg X5d shows a sequence of small squares
You need a reprogramming done from the Maker . Contact Authorized Korg Service center . Be away from frauds.
dr_mosh
Mosh
  • 41 Answers
  • Posted on Jun 12, 2011
SOURCE: Hi, my korg X5D have
The pitch and modulation wheels are on a separate circuit board, if they both stopped working at the same time, it's likely the connecting cable has dislodged.
Opening an X5(D) is relatively simple and you should be able to simply plug the cable back in. If you're not comfortable doing that, take it to a shop.
How to fix korg x5 system error
https://www.google.com search of the internet gives the following result:
https://www.sweetwater.com/sweetcare/articles/initialize-reset-preload-korg-x5-x5d-dr/
How to Initialize (reset), and preload on the Korg X5/X5D/DR
  • Article #16230
  • Updated on Apr 27, 2007 at 12:00 AM
Initialization: Hold Page + and Page - while turning it on.
Preload: Global Screen 5A, then select "OK".
ROM Check: Hold Edit and Global/Multi while turning it on.
Jan 16, 2020 • Korg Music
When i star or on my korg x5d the display are just like cherismas light it does not finishe inistalation and logo of korg x5d then it will be empity lignht scren
How to Initialize (reset), and preload on the Korg X5/X5D/DR Initialization: Hold Page + and Page - while turning it on.
Apr 17, 2016 • Korg Music
How to reset korge x5d to factory setting?
Hold PROG and +10 while turning it on.
That should initialize the unit to factory fresh.
Aug 07, 2014 • Korg X5d
The pitch of my korg x5d is D#, how can i get it back to its original set up
Press:
1- GLOBAL
2- PAGE+ or PAGE- ,untill the display show "TRANSPOSE".
Set the value to "0" using YES / NO or VALUE slider.
Apr 11, 2013 • Korg X5d
Crackling speaker as soon as i switch on my digital piano
It looks like the Korg c-15s has a internally mounted speaker and so I will assume that the speaker and amplifier are part of the piano base. It sounds like either the speaker is blown (crackling sounds heard as deformed voice coil scrapes the magnet structure) or the audio amplifier is distorting the audio.
Connect the piano's output to an external amplifier and speaker to properly identify problem.
Oct 17, 2012 • Korg Music
3answers
My korg x5 keyboard only turns on but nothing comes out of the display.nothing is loaded and no characters displayed.
Download the owners manual from here and try doing a reset to factory settings
http://www.korguksupport.co.uk/page.cfm?pageid=391#Owners Manuals
Feb 18, 2011 • Korg X5d
Hi. My Korg X5d shows a sequence of small squares in the display panel and will not boot. Can you help?
Nov 18, 2010 • Korg X5d
Top Music Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Music Expert? Answer questions, earn points and help others
