Forgot password to acess< and or its still default setting. could you tell me what the wireless 700 routers default password is
Restore Factory Default Settings
When you restore factory default settings to the base station, you clear your Internet connection settings and any
special base station configurations that you have established. After the restore is complete, you will need to
reconfigure your base station settings or restore these settings from a backup file.
You should restore the original factory default settings only under the following circumstances:
O You are experiencing serious problems with your base station, and resetting the base station does not fix
the problem.
O You cannot remember your base station password. In this situation, you must restore the factory default settings
by using the Restore button on the base station, and then use the default password admin to log on to the Base
Station Management Tool.
To restore factory default settings
1. Open the Base Station Management Tool, and then click Management.
2. On the Management menu, click Back Up and Restore Settings.
3. Under Restore factory default settings, click Restore Factory Default Settings. While the original factory
default settings are being restored to the base station, the Power light on the base station turns orange. When
the light is solid green, the settings have been restored.
If you want to open the Base Station Management Tool after the settings have been restored, type admin as the
password on the Logon page. Do not attempt to log on to the base station until the settings are restored and the
Power light on the base station is solid green.
After you restore the factory default settings to the base station, you should navigate to each page of the Base
Station Management Tool and reestablish the network settings you want, or restore the base station settings by
using a backup file. For information about creating a backup file of your settings, see the following section.
Be sure to establish your unique base station password as soon as possible after restoring the factory default
settings to prevent unauthorized users from logging on. For more information, see “Change the Base Station
Password.”
please rate this answer, thanks
Channels such as MUTV,Setanta Sports 1, Setanta Golf etc dropped off yesterday. Tried rescan etc, but no joy.
I have tried a auto rescan and a manual rescan to no avail??? Help Am I doin someth wrong???
