Copytechnethttps://www.copytechnet.com > ... > Canon
Nov 26, 2020 - Check the connection of the Flexible Cable between the DC Controller PCB (UN9) and the Main Controller PCB2. -- removed and re-connected ribbon ...
This is a reader communications error. It's been a long time since I worked an IR-C3200 copier but all cables must be plugged in. They will only go where they were intended to go. Reseat all those cables and good luck, other wise you have a professional help problem. Make sure all the cable checks are done with power off. Then power up agai n and see what happens.
is there an error code appear on panel display? if there a error appear try to reset you may press * key,press 2&8 simultaneously, the select copier then select fuction then clear then error then ok then turn off& on
CODE ERROR C3200 OLIVETTI
