The power all seems fine but but then the lights at the top of the keypad (number lock, cap lock, shift) go weird. The number lock (button with a a lock and a number in the middle) starts flashing. The screen doesnt do anything and is just black.
Ive tried holding function and the number lock button down...screen is completely dead.
Same thing happened to me.
I stumbled on this link and the solution made sense to me.
http://en.community.dell.com/dell-groups/new-to-community/f/3511/t/19323146.aspx
What I did was to nudge in the Hard drive to make sure it wasn't loose and press down slightly on the processor even though it didnt feel loose.
Worked for me. Though I'd help someone else since someone else 's post helped me.
Try reseating the ram modules, see if any difference. IF not, try them one at a time. If issue occurs with only 1 ram module, replace that RAM. If any conbination of RAM causes issue, of if no ram will work in 1 slot, then replace the motherboard.
http://support.dell.com/support/edocs/systems/vos1510/en/SM/html/trouble.htm#wp1094697
1. Remove RAM (or RAMs) , clean it and then replace it, if your problem solve that is good and if not:
2. Graphic Chip In Main board not work properly and must be replaced (or Reball) in a laptop repair center. (if your laptop has age longer than 3 or 4 year this problem is normal in vostro 1510). also you can replace your Main Board.
you can read more about laptop DELL vostro 1510 and its problem in
www.teliaservice.com
The power is ok but when hold the power button to get the computer started , the screen doesnt do anything and is just blank.
my dell vostro 1510 can't boot, when i push power button on, caps and scroll LED stay on while number LED blinks, nothing shows on screen, black screen, tried using each RAM but no change, removed both RAMs and nothing yet, no beep sound! Is the motherboard bad or can anyone help me out? thanks in advance
I have a Toshiba Satellite C850 1D2 laptop which had a small amount of tea spilt on it
It was fine for a couple of hours but then the screen went black and the caps lock and number lock lights do not come on when the laptop is switched on
Any help on what to do would be grately appreciated
