Have to hold down tank handle for it to flush all the way.
SOURCE: flapper will not go down
Troy, the flapper otherwise known as the flush valve is easily replaced. They are also very inexpensive. Sometimes they can become distorted due to the clorine in the water and won't operate in the same way they did when it was new. I bet this will fix your issue and save you money as well.
SOURCE: Kohler two peice toilet the water just circles
These models need to have a flush valve flapper that has a styrofoam float on the lift chaninof the flapper. Go to hardware store or home improvement store and get a 'Korky brand toilet tank flapper with float 'ball". Cut the rubber ring piece away from the flapper and you don't need it (see cut here marks on flapper). Install flapper and adjust the float fairly close to the flapper.
When the water level drops in the tank and reaches the level of the float on the opne flapper, the flapper quickly closes causing the toilet to have a "surge" of siphon action which forces the water in the bowl to be drawn out.
SOURCE: Pegasus Dual Flush Toilet - How to repair damaged handle
any good plumbing supply company will help you. " Furgoson " i think thats how you spell it.
SOURCE: pegasus HET toilet splashes water when it flushes
make sure the fill valve is not cracked,that's the long tower looking thing on the right side of the toilet when you stand in front of the unit. you can replace this part at homedepot. it is called a fluidmaster 400A.good luck.
SOURCE: My toilet is a duravit 1930 series model with Euro
A fairly easy ( but messy ) fix - get a replacement tank to bowl gasket and bolt kit, shut off water supply, drain tank, remove bolts ( you might have to cut, depending on your water source and minerals in your water). Remove old gasket and clean surface with 00 grade steel wool. Replace gasket, install new bolts, remount tank.
Good luck!!
Testimonial: "that was my impression so thanks for confirming and clear explanation of whats involved."
