I have a Vtech 1920c and the power light is on and the charging light is blinking. The phone is now dead. I am assuming that the battery is gone and needs to be replaced. Please advise. Thanks.
Yes, your assumption is likely correct. A rechargeable battery thats life is up, will still show its charging indefinitely. However, I've also seen the same scenario with bad recharging base, even in high dollar units. I would recommend replacing the battery first, because that would be the least expensive option, and most likely to fix it.
Also, you can return the battery if that doesn't work.
If its the base, its probably cheaper to just buy a phone, unless you just happen to have a local place that does repairs on electronics, and they can do it cheaply. Likely, they'll tell you that its not cost effective to do a repair though.
Hope its just the battery.
