Question about LawMate PV-RC200HD High Definition Covert Key Chain Hidden Video
Blue light keeps flashing, nothing works
When I turn on the Lawmate PV-RC200HD Key Chain a blue light starts to flash non-stop. And I can only shut it down again. No recording or taking pictures is possible. How can this be fixed again?
My 96 caprice classic vats security system has y car shut down. I had a after market ATS security chip also in my car and I removed it thinkingvthat was the problem. It wasnt.
OK. Turn on the key, let the light start flashing. Leave the key in the ON position. Leave it that way for 10 minutes. The VATS security is supposed to discourage a thief from stealing your car. It will flash for 10 minutes and then it will stop flashing. Now,,,,,, DO NOT turn off the key. DO NOT turn it off. Simply take ahold of the key and crank the car up. It will start and should never happen again, unless someone removes the instrument cluster, the battery, or other vital items like the ECM PCU. Good luck.
Dec 25, 2017 | 1996 Chevrolet Caprice Classic
The blue power light and the blue and red battery lights keep flashing and won't stop Why?
Sounds like the battery itself is going bad and needs to be replaced. The blinking lights are a code that you can find at the OEM website and it will tell you exactly what is going on..
Feb 01, 2014 | Acer C7 Chromebook
Afterglow Wireless Headset Blue Flashing mic light
i have the same problem. i am worried. i was playing counter strike and we finished. everybody was congratulating. shortly after a loud beep a bit lower pitch than the turning of and on noise that the headset makes. i turned it on and off. the only thing that stopped the beep was to mute the mic. fiddles with the 2 buttons, the light dimmed greatly and the mic started blinking blue. if you are able to find any way to fix it please contact me on skype : Sassy_Sasquach. Thanks!
Jan 23, 2014 | Radio Communications
LawMate PV-AC30 manual
To set the time / date stamp you'll need your remote control and you'll need to hook it to a TV with AV inputs. Be sure to correctly select the AV input the camera is plugged into. This is the most overlooked step that causes a lot of users frustration.
I've attached a YouTube video on how to accomplish the time/date setting.
Aug 28, 2012 | LawMate PV-AC30 Wall AC Adaptor DVR...
I am seeking a replacement LCD screen for my Lawmate PV900 anyone know where to get one have searched but no luck
You will need the serial number from rear of screen or on ribbon connector
Then google it that will point you in the right direction
Aug 22, 2012 | Kjb Lawmate Pv-900 Dvr Pi Video Camera...
2002 malibu 3100 v-6 won't start, getting fuel and fire to all cylinders
if the security light is flashing than the anti theft is active. The anti theft shuts down the injectors and will not let the vehicle start.
You'll need a battery charger to do this. Hook up the battery charger to the battery.
Place the key in the igniton and attempt to start. Let the key return to the run postion and leave it there untill the light stops flashing. Turn the key off
Turn the key on (do not try to start) and wait for the light to stop flashing again.
turn the key off and then try to start the vehicle.
You can google search "resetting gm security" and find this info as well.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Feb 03, 2012 | 2002 Chevrolet Malibu
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
LawMate PV-RC200HD High Definition Covert Key Chain Hidden Video Logo
110 people viewed this question
Top LawMate Video Cameras Experts
Marvin
Marvin
Are you a LawMate Video Camera Expert? Answer questions, earn points and help others
