If you have changed the tax rate, it should print out the change you made to confirm the change as soon as you finish programming. After that, it should use the new rate. If it is not adding tax to items, make sure you have linked the tax rate to the items in PLU or dept programming (whichever you are using)
i have cash reg. gold 2100 , and i programed the cash reg for (7.5 % to 8.5% ), by changing the 1508030 tax shift 2 to 1509030 tax shift 2 while the key is on program position.
the steps from beginning :
first: put the key on prog position.
2nd: enter 1505000 then press tax shift 1 ( 5%)
3rd : enter 1509030 then press tax shift 2 ( 8.5 %)
4th : enter 037000000 dep 1 ( tax able )
5th : enter 037000000 dep 2 ( tax able )
6th: enter 037000000 dep 3 ( tax able )
7th: press # / no sale .
put the key to reg position and try it . good luck and happy new year.
move the key to pgm mode
3 subtotal
125 subtotal ( that is the tax table)
9.25 cash ( don't digit the point the register will put it for you)
5002 cash
10 cash ( this is the beginning level for the tax in this case is
ten cents)
subt.
To applay tax to dept.:
in program 3
366 subtotal
1 and touch all depts that you need with this tax.
move the pgm key to pgm mode 3 subtotal 125 subtotal ( tax table) rate tax and subtotal beginning level tax ejemplo : for ten cent = 10 and subtotal 5002 subtotal subtotal. to applay the tax to dept or plu move the pgm key to pgm mode 3 subtotal 366 subtotal 1 and all dept o plu subtotal
KEY REQUIRED: PGM KEY
TURN KEY TO PROGRAM MODE:
ENTER 3 PRESS [SUBTOTAL]
ENTER 0125 PRESS [SUBTOTAL] ENTER 070000 PRESS [CASH]
ENTER 0 PRESS [CASH]
ENTER 5002 PRESS [CASH]
PRESS [CASH]
PRESS [SUBTOTAL]
TURN TO REG POSITION
The BOLD Underlined entry indicates the tax line...this example is for 7%
3 subtotal
5002 subtotal
subtotal.
3 subtotal
366 subtotal
subtotal
Hi. If you bought it new then your dealer should have set all of the system options for you so it is strange that the tax is not programmed. Normally you would only need to set the rate when your tax rate changes. Has it been calculating tax at all? Did it come from your dealer with a standard program in it?
