I forgot the password for sim lock.it says incorret password . kinfly help
SOURCE: sim lock samsung sgh e370
You can try the master reset code of 00000000 just keep hitting zero until it won't put anymore in, or 8 x zero. This may work but I doubt it. Most times when you do this as with puk codes you will need to have it fixed via a tech with the required software and cables to bypass the sim lock and reset it to factory. You should not need to lock your sim anyway as most phones have a scurity feature that allows you to put a passcode on your phone, so if you turn it off or it goes flat, you charge it and turn it back on, you are required to put in the code to use the phone and I suspect this is what you mean a personal phone lock code not a sim lock code. As to unlock a sim and change the codeing you will need the original code from the sim supllier and I have never heard of or known anyone who has been given this particular code. The only way I know you can get a sim code is via a hack. Which is illigal in every country I know of. Some phones however do call this feature a sim code and this can be missleading when this sort of a problem happens. I do hope the master code built into the phone works for you, but this code can be readily changed by the user and if it has been by your son it could be anything. And if the master reset code does not work you will have to take it to a phone tech and have it flashed or maybe they can bypass the code without flashing the phone as a flashed phone will not have any info you or your son put on it anymore. It wipes the phone memory and software and reinstalls it back to factory( AS NEW) hope this helps you but I do think you will need to take the phone to a tech.
SOURCE: how to unlock
Input the password 3 times to lock the phone then the phone will ask for a PUK code.
Call your mobile phone company, give them your mobile number or SIM card number to get the PUK code to unlock the phone.
SOURCE: how to break samsung d880 sim lock password.
The best bet is to put your original sim (d880) , but don`t lock it.
Ring the supplier for this sim explain the situation and they will unlock it for you.
Your second sim will then work in your phone , no problem!
SOURCE: can someone help me unlock my cellphone t749 sgh
Well I'm happy I can help you.The same problem happened to me and my Samsung Highlight T-749.First, I called Customer Care and they tell you to type in some passwords.If,the passwords they tell you to type in don't work,then they will give you the option of buying a new sim card.The sim cards usually cost about 20 bucks but don't worry because you can back-up the data in your old sim card to your new one.Hope this helped you!
Testimonial: "thanx for the information"
