Question about Onkyo TX-SV454 Receiver
Stuck in protect mode
Hello, My Onkyo TX-sv454 is stuck in protect mode. I opened case and I don't see any problems. Is it possible for me to reset it. Thanks
  • Anonymous May 16, 2009
    My Onkyo TX SV454 receiver turns off immediately after turning it on. It says "PROTECT". Help!
    Mitch
I believe protect mode is because you have the wrong impedence speakers, they are too low (4 ohm? 6 ohm?) it chols work with 8 ohm speakers
Posted on Dec 11, 2008
    Dedicated:
    Visited the website for 20 consecutive days.
  • 145 Answers
Onkyo TX-SV454 Speaker impedance set ranges...If you are using A or B :6 ohms min./speaker. If you are using A plus B :12ohms min./speaker. Rear (surround) speakers 6 ohms min. /speaker. Center speaker 6 ohms min. These are the guidelines to follow from manufacturers settings. If you are in range of these guidelines and “protect” still reads, you have another problem.
Posted on Jun 26, 2019
SOURCE:
My ONKYO tx 8511 is protect mode How to reset
Hi Vinoth, if this has not been resolved I would advise you to disconnect the unit from the AC Outlet for at least an hour and then see if it is out of Protect Mode, Thanks, JT
Nov 19, 2015 | Onkyo Audio Players & Recorders
Protect mode on my onkyo sv515proii what does it mean?
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
Jul 30, 2011 | Onkyo TX-SV454 Receiver
So what do i do if when i turn my onkyo tx-sv454 receiver on it says protect and then shuts off? How do i fix that or get around it? please help me....
I don't think you can fix it, unless you're skilled with electronics. Possibility that something has occurred internally with a circuit board etc so the system shuts down in order to protect itself from catching on fire etc. Get it services. Might not be too bad of an issue, but certainly not a bypass.
Mar 02, 2011 | Onkyo TX-SV454 Receiver
How do I reset from the amp protect mode Onkyo receiver TX-SR600?
How do I reset my amp / receiver from protect mode ?
May 07, 2010 | Onkyo TX-SR605 Receiver
Surround mode is set to OFF
I was able to solve this problem by using the "A" speaker jacks and eventually I pushed the right buttons to get the Surround mode to turn ON. I believe it was when I hit the Parameter Selection button that allowed the surround mode to become active.
Jan 18, 2009 | Onkyo TX-SV454 Receiver
Onkyo TX-SV444 problem
the shorted spkr wires probably fried the putput transistors in that channel.  Do you know how to use a Fluke  test meter on diode test
Dec 31, 2008 | Onkyo TX-SV454 Receiver
Onkyo ts595 goes into protect mode with volume increase
Hold the VCR/DVR button in and press the ON/OFF Standby button. The display should briefly read CLEAR and then the unit switches off. If that clears protect mode, you'll need to redo the Audyssey and configuration setup as these will have been cleared by the reset.
Sep 27, 2017 | Onkyo TX-DS575 Receiver
Onkyo tx-sv535
when the apm in protect mode means it is problem in inside.don't trow it please repair it n use
Jan 02, 2008 | Onkyo TX-SV535 Receiver
Onkyo tx-sr800 PROTECT mode
Hold video1 and press speakers A button, it will say "clear" If the message protect appears again, then its service time.
Aug 28, 2007 | Onkyo TX-8511 Receiver
Help
You need to replace the internal fuse.
Aug 25, 2007 | Onkyo TX-SV454 Receiver
1,398 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
