My weight watchers scale reads ron when you tap it. I have put in a new battery but nothing changes. It only reads ron and cuts off. Please help I have only had this scale a short time. I have been to several web sites but there is no solution.
now scale reads err with no weight on it. When it turns on it goes straight to errnow scale reads err with no weight on it. When it turns on it goes straight to err
You can't post conmments that contain an email address.
It is possible to switch the weight measurement on a BlueTooth Weight Watchers scale, Model WW941R, from kilograms to pounds through the use of the Weight Watchers app. To do this, follow these steps:
Download and install the Weight Watchers app on your smartphone or tablet. Open the app and sign in to your Weight Watchers account. Tap on the menu icon in the top left corner of the app. Tap on "My Account" and then tap on "My Devices." Select your BlueTooth scale from the list of devices. Tap on "Device Settings" and then tap on "Units of Measurement." Select "Pounds" as the unit of measurement. As for the BT name, it is possible that the BlueTooth name of your scale is "WW941R." You can try searching for this name when pairing your scale with the Weight Watchers app or another BlueTooth device. If the name is not displayed or if you are unable to pair the scale, it is recommended to consult the user manual for your specific scale model or contact the manufacturer for further assistance.
The first thing would suggest is changing the batteries. A flickering display is the first indication that they are failing. Depending on the type, they take AAA Duracell batteries or 2 x CR2032 batteries. That model number seems a bit funky, WW11D manual is in this link.
My Weight Watchers digital scales model#ww39 has gone haywire. I put new batteries in it to no avail. You tap it and the numbers come right up then changes to 000.0 as it should, when you step on the scales the numbers flash as they should but either they weight you about 100lbs to heavy or the numbers continue to blink and the LCD goes blank. Can they be fixed? Can I fix them myself at home? Do I need to shoot them? Just throw them out in the yard? Please I need help!!
