There are normally little drop down tags that screw on to the legs at the top so that when you lift the side up it runs over these tags which then drop down to keep the side up.
Contact Products America. We will do our best to help you with your metal hardware. We carry a large array of metal hardware. [email protected] or 800-205-9642
You havent given us enough detail. When you say 'Bottom Spring" do you mean the mattress support?
The drop down bars bolt on to the headboard or footboard (one each) and let the dropside move up and down, held in place by the bars. The backside usually has bolts that run thru the head and footboard
to attach them. Some just have small nubs that the top of the backside sit onto and a bolt holds the
bottom of both sides. If you wish to send a picture of what you have for further details, send
it to [email protected]
I will help you get it right.
This is tricky but I have put it together and taken it apart countless times (3 kids, 2 houses and everyone switching rooms). All of the screws keeping the crib together need to be as loose as possible without the crib coming apart. I found it easiest to have someone help so they can help hold the crib. It's important not to pull the drop side apart as it will break the plastic slides (I've done this and had to replace them). Have your helper hold one side of the drop crib right against the side piece of the crib and slide the drop side down to detach it from the side your helper isn't on. once this side is detached do the same for the opposite side. On the crib side that attaches to the drop side is a "screw" that slides down the plastic slide and a "peg" at the bottom. I always get the peg out of the track and then you can slide the screw all the way down the slide to get it out.
dear debbie... yesterday i was given the complete jenny linn nursery. i have all the parts and hardware. where were you able to find the assembly instructions? can you help?
The company said this is discontinued and cannot be replaced. They no longer use this type of latch bracket. I guess we will have to purchase a new crib.
Try www.productsamerica.com they sell replacement parts and also conversion parts for older cribs. They are a little on the expensive side, but they are on the only place on the net that I could find for this.
Their number is 800-772-1041. You can call them and give them you make and model that they can match up what they have with what you need.
They do have answers on their website, you may want to check your printed or online crib instructions to remind yourself how you put the crib together, too.
I found the answers here: http://www.pali-design.com/index.php?path=customer_services&template=faq§ion=customer_services&subsection=faq&page=faq
i've pasted them below. You can make it a toddler bed without a side rail just by removing the movable side of your crib, and you can install the side rail instead of the movable side if you want it to look a little more finished and help keep your child from rolling out of the bed.
FAQ
How to convert a crib into a toddler bed To
convert a crib into a toddler bed you must loosen the two front gold
bolts left and right side of the crib and remove the dropside (the
front gate that goes up and down). After removing the dropside be very
careful that you tighten back your two gold bolts.
How to install the streight rail (toddler rail) To install a streight (toddler) rail
loosen the two front gold bolts left and right side of the crib and
remove the dropside, once you have removed the dropside replace with
the streight rail. Always be very careful and make sure you tighten
back your two gold bolts in the front.
