How did you solve this?
To take it out of energy saver mode and back to manual operation, press the up and down temp. Buttons at same time and hold em in. Then press the off switch 2 times fast. Display will change to two dashes, then Let go off tem pop buttons , press heat button once. Then tem o up button until 0 appears in display. Hit off button again and it should be in manual mode.
How do I turn it back on to energy saver?
Http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=PTH153B50AJ&siteCd=AMA
This is the link to find the manual for your unit. Make sure the model number is correct. You should be able to find the info you are looking for if it is possible to disable the energy saver. Hopefully this will help.
