Sounds like the system defaulted programming.
Depending on the type of prostar 616 the only ringing station would be 1(or 21) with the porstar or 4(or 24) with the prostar plus.
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down, enter #20 the screen should say MMC DISABLED
enter in 1 2 3 4 1 # (that enables
programming)
enter in #62 the screen should say day
ring assn
press the line you wish to program
press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
press # when finished with the line
repeat steps 2 through 5 for the remainder of the lines you wish to change
press # when finished.
To program system speed dial numbersyou need the customer programming enabled (see the first part of programing ringing)
press the ALM/SD button
dial the 2 digit speed dialcode 10-98
dial the telephone number to be stored in that speed dial bank
press ALM/SD to store the number
