My JVC DVD is fine in that it plays anything and everything, but all of a sudden it will only play in black and white. I have checked scart connections and throughly cleaned it inside and out. Any suggestions please ...... Mic.
SOURCE: Jvc xv-s302 only plays black and white
Look at the back of the DVD player it should have a NTSC & PAL switch ,but remember to switch off the dvd player after you change it over to NTSC or PAL
i hope this will help you
craig:)
SOURCE: DVD ONLY PLAYS IN BLACK AND WHITE
figure out if yout tv and your dvd is using the same color system, check also if you installed your rca connector on proper video output of your dvd dont interchane yuv to video out connectors ,check also your dvd's video out setting ,like interlace, pc,yuv, rgb, if you are using video in on your tv you should select s-video or interlace if you are using yuv on your tv you should select yuv on your dvd
