it sounds to me that your electrical contacts are not tight or the motors windings are overheating so seak the help of an electrician and ask him to test the start and run amperes of the system if thats fine then i think your pump seals are faulty
The gasket around the jet may be leaking because it is deteriorating or the flange nut on the outer side of the jet has loosened up. Check all jets for loose hardware.
Did you see any mold? Did you see any areas that are wet? TOXIC is a term that is used to describe something that is poisonous. I think you mean noxious which means unpleasant and possibly harmful. The smell of sewage would be classified as this.
Any time you get a strong smell of rotten eggs it is due to a high concentration of sulfer in the water. Are you on well water? I would suggest using a cleaner like http://www.sani-bath.com/ to clean out your system.
the jet covers normally unscrew counter clock wise .As far as the smell goes it could be clumps of old hair after time the old hair usually causes a pretty bad smell.Try snaking the drain.This might help.
