Kitchenaid dishwasher kuds01flss
it's suppose to be quiet, but it's now making a noise when it starts up and during some of the cleaning process, like a bad fan, it's probably the motor. The dishwasher is 4 yrs old, we've already had to replace the part which keeps the door from slamming down. There are only 2 of us, so we may wash dishes once a week.
SOURCE: Kitchenaid Superba Dishwasher
gagaweaver, couple of things you want to check here. Check the upper spray arm for any clogged holes or cracks along the edges. Position it in the 12:00 position and run the dishwasher for a little, open the door and verify that it has rotated. Make sure the water entering the dishwasher is min. 120 degrees, use a thermometer. Makes sure that there is no large pans or dishes blocking the upper spray arm from spraying onto the inner door. If all that checks out. You will have to remove the lower spray arm, filter cover and chopper cover to make sure the chopper screen is not coated or plugged up. If it is, it will prevent a good flow of water to the upper spray arm. Catriver..post back.
SOURCE: KITCHENAID DISHWASHER NOT CLEANING PROPERLY;
there's a filter at the bottom of the inside of the washer. remove the rack and spray arm and you can get to the filter and clean it out. once cleaned you will notice a difference after each cycle.
SOURCE: My Kitchenaid dishwasher not cleaning dishes on top shelf
You need to clean the jets on the machine arm with an old toothbrush etc... then clean out the debris filter on the bottom of the tub near the dryer bar. The calcification in the little jet areas causes this problem. This should help.
SOURCE: Child lock shut off
Hold the button with the lock until the light turns off. Consult the manual.
Can you provide a model number?
SOURCE: KitchenAid dishwasher soap door won't open
I took the door apart and found the degertent door solinoid looking like it over heated and melted to the cover flap and the insulation. See picture. I can't post pic as the max is 150kb.
I applied power and it only got hot and wouldn't operate.
Next I go to Kitchenaid for a replacement - FREE it should be.
