Question about Casio Privia Px330 Px-330 88 Key Digital Piano New
Does the casio AD A12150LW MAINS ADAPTOR HAVE A FUSE INSIDE
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 73 Answers
No - the fuse is inside the keyboard. Or at least it should be. On your particular model have a look on the underside of the keyboard (where your knees go).
Posted on Nov 26, 2013
SOURCE:
Got a used CTK 720 and it has no power. sugestions
try plugging in without the bateries...Also check your adaptor as well as your ac requirements on your keyboard..It specifically calls for a Casio AD-5 Adaptor.
  • 9V power supply; 850mA
  • Positive sleeve/negative tip This needs to match your adaptor Good Luck
http://support.casio.com/pdf/008/ctk_720_01_e.pdf
Feb 15, 2015 | Casio CTK-720 Electronic Keyboard with...
My Privia px200 won't turn on, what is the problem
First get a new 12V DC power supply (AC Adaptor model AD-12) to test.
Otherwise it needs repair by Casio technician. Main PCB board may need to be replaced.
May 29, 2014 | Casio PX200 Privia Digital Piano with...
Why does my Privia px200 won't turn on?... is the adapter the problem.
Use a multimeter to test the AC Adaptor (AD-12) for DC 12 volts. If no voltage buy a new one.
May 29, 2014 | Casio Music
Keyboard wont play with ac adaptor
Hi, Assuming you have tested with another adaptor then invariably it is a broken solder joint on the power input connector.
Re soldering will work but eventually the same thing occurs.
Set the connector in epoxy resin (Araldite) or better still mount a new connector in the case and wire with flying leads.
All the best, Chris the Fader.
Apr 04, 2014 | Casio Ctk 496 Electronic Keyboard with 61...
Computer does not have Ctk-720 driver
PC drivers available at Casio
http://support.casio.com/en/support/download.php?cid=008&pid=20
If you have a MAC google casio driver for Macs by 3rd party.
Jan 22, 2014 | Casio CTK-720 Electronic Keyboard with...
Correct adapter for casio wk 500
Casio AD-12 for my country with 240V
You may use any 12V 1A AC Adaptor that has the same DC jack provided the center is NEGATIVE. Most common generic AC Adaptors are Centre POSITIVE.
So cut DC end of the wire and solder them in reverse and insulate with tape and it will work.
Jan 20, 2014 | Casio Lighted Keyboard LK90STADMC
The power adaptor will not work on my casio cps-80 s Thanks,
You need to use the standard Casio adapter for the unit.. What adpater are you using? Sometimes the connector within the keyboard gets broken.
May 02, 2011 | Casio Music
We are trying to buy a new adapter for a Casio CA - 100 Keyboard and we live in Watford Hertfordshire. Can you tell us of a supplier we can contact please
http://www.musical-instrumentsuk.co.uk/ The adapter you need is the AD-5EL and is listed at this store. I found this info at this website:http://www.twenga.co.uk/dir-Leisure-Hobbies,String-instruments,Keyboard-power-supply-adaptor-45 I am in Canada so I hope the store I mentioned can help you. If they aren't in your area a shop that sells Casio products should be able to get you that model adapter. I hope this helps you.
Aug 10, 2009 | Music
Casio Privia Px330 Px-330 88 Key Digital Piano New Logo
126 people viewed this question
Top Casio Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Casio Music Expert? Answer questions, earn points and help others
