Question about Hoisting
I'm pulling the lowering lever, why won't the forks on my pallet jack go down all the way?
    New Friend:
  • 152 Answers
First of all, the forks are not supposed to go all the way down to the floor, that would defeat the purpose because they would drag and you wouldn't be able to pick up a pallet. But if you think the forks should be able to go down further, just stand on the forks while pulling the lowering lever. You may need to grease the machine
Posted on May 27, 2013
SOURCE:
Pallet jack will not go down
Is it a manual pallet jack? At the base of the arm you will see a lever that the handle controls (usually it is at the end of the chain). Assist the lever by pushing it in further than the handle can able. That should allow the lift to lower. Sometimes the pallet needs to be level to lower. If it is a powered lift, check the limit switches. Good luck!
Feb 21, 2016 | Cars & Trucks
Tip
Different Types of Fork Lift Trucks Forklift trucks are very powerful...
Forklift trucks are very powerful industrial trucks that are used for
both lifting and transporting of materials.These days building
projects all use forklift trucks.
There are many different types of forklift truck. Here are some of the
most well known;
Electric forklifts - these forklifts are powered by lead-acid
batteries and includes scissor lifts, stackers and pallet jacks
Sideloader - this includes both Stand on End Control and Sit Down End Control.
Hand pallet truck - a pallet truck that is usually electrically powered.
Truck mounted forklift - usually a diesel run truck.
A small percentage of the forklift truck market includes high-end
speciality trucks.
In more recent years, Automated forklift trucks have been developed in
order to try and reduce the wages paid and operational costs of
running regular trucks. The popularity of automated forklifts has
grown massively.
on Nov 21, 2013 | Heavy Machinery
What is the difference between a manual pallet jack and a powered pallet jack?
As the name suggests, for manual pallet jacks you walk behind the forks and pump the handle to raise them/lower them. On powered, or electric, pallet jacks, there is a throttle for moving and a lever for raising/lowering the forks. On some powered pallet jacks, there is a platform for the operator to stand on
May 27, 2013 | Hoisting
What are the common specs for the forks on pallet jacks?
fork width= 7 inches
fork length= 36, 42, or 48 inches
fork height= 2.9 inches
fully raised height= at least 7.5 inches
length between outer edges of forks= 20.25 or 27 inches
Jan 16, 2013 | Hoisting
How do i lift the forks on my pallet jack?
push the lever on the handle outwards. when you want to lower the forks, pull the lever in
I have a 9960 singer machine and am trying to use the buttonhole presser foot for the first time and I can not get it to sew T
the buttonhole foot snaps on to the presser bar, there's a little lever at the back of the presser bar that releases the foot, then put the buttonhole foot down on the needle plate & use the presser foot lifter (number 11) to lower the presser bar down onto the buttonhole foot & you'll hear a click sound when it snaps on & make sure to use the buttonhole lever(number 31) because the machine won't sew a buttonhole unless that lever is pulled down.
Apr 26, 2012 | Singer Sewing Machines
Pallet jack won't let down. The lever is moving the cam on the side at the bottom.
9 out of 10 times its the Valve in the rear of the piston housing the one that you pull the lever to let it downor kick with your foot as the valve return isent returning.back to the header tank..
Sep 27, 2009 | Home Fencing
Hoisting Logo
1,913 people viewed this question
Top Hoisting Experts
JAIJITH
Andrew Taylor
Andrew Taylor
Pierre Laplante
Are you a Hoisting Expert? Answer questions, earn points and help others
