Question about Jaeger-lecoultre Master Compressor Memovox 1708170 Wrist Watch
Memovox monoglock case 911
How to open a memovox with caliber 911. Use "pince 1335 wrench" is engraved at the back of the case. Howe does such a tool like. Can that, or a similar, that will do be acquired
What is the price of winner rolex24ad daytona1992
With certificate $15,000 as of june 2013. Genuine Daytona has no engraving. Counterfeiters often have engraving on case-back
If you need further help, reach me via phone at https://www.6ya.com/expert/timothy_c6f309c0f75b6f43
Jul 17, 2014 | Rolex Watches
R ingraved on back
A personalized engraving on the back of a watch case means nothing as far as its authenticity is concerned. Think about it an engraving can be done at any time after the manufacture of the watch is completed so how could an engraving or lack there of tell you anything about authentic? I bought an older Day-Date President a month ago and it had the persons name, birthday, and SOCIAL SECURITY NUMBER engraved on the back. What is interesting about this particular engraving is that it is a fairly bad engraving. Which means that an unskilled person did the engraving, but that is all it means. The particular watch I am reffering to is very real indeed. All that aside I'm going to say that your watch is fake. That is a 20K watch and the fact that you don't know how the engraving got on there indicates that its more than likely not real. That's also one of the most commonly counterfeited Rolex's. If you wanna know for sure take it into a pawn shop and tell them you want to sell it. Just don't argue with the people when they tell you its fake.
Dec 16, 2013 | Rolex Daytona 116520 Wrist Watch
How do you take the back of a wrist watch off so you can change the battery
The Proper way is with a "watch case wrench". They can be purchased for a few dollars on Amazon and E-bay. In most cases unless you are changing many watch batteries the best option is to call around to local jewelers and pawn shops and ask how much to replace a watch battery. In my town it ranges from $30 to as little as $5.99 battery included.
Dec 14, 2013 | Meco 2PCS Watch Case Back Opening Tool...
I have a vintage ladies wrist watch by CYMA. There seems to be no lip to catch on for opening the back. Does it unscrew?
If the back of your watch is completely smooth, the odds are that it has a snap-fit case. Screw-back wristwatch cases generally have small indentations in the case back into which you fit a case wrench. Rolexes have an elaborately ridged edge to their case backs and take a special wrench. A few early water-resistant watches have little screws that hold the front and back of the case together, but these are usually quite obvious, and you didn't mention them in your description.
Most "fancy" ladies watches of the 40s, 50s, and 60s, had snap-back cases. To open one of these without damaging the case, I recommend gently working a decent quality case knife into the crack where the case back joins the case and gently levering up. If the case is really snug, you may need to do this in a few places to gradually pry apart the case halves. Often, the best place to do this is at the lugs, because they offer a leveraging point. I don't recommend doing this with a sharp knife blade, as the resistance from the case will probably damage the knife edge, and if the knife slips, it can easily scratch the case. If you don't have a case knife, try using the rounded edge of a butter or table knife. Do not use a flathead screwdriver blade, as the short width of that tool can easily place so much pressure on a small section of the case that it deforms and can never be made to look good again.
May 13, 2011 | Watches
How to open the back
Determine the type of case back on the watch. Set the watch face down on a soft surface and look at the back. If it has slots, it is defined as a screw-back case. If it is smooth, it is defined as a snap-back case.
To open a screw-back watch, use the metal blade of a standard screwdriver to turn the slots counterclockwise. A case-back wrench, which can be purchased at watch-repair stores, can also be used. Set the metal tips of the wrench into the back's slots and turn it counterclockwise to open.
For a snap back case, place the metal blade of a standard screwdriver in the indent between the watch and the case. Gently apply pressure to lift the case up and off of the watch.
Close the case back by setting it back onto the watch. For snap-back cases, line up the indent on the side of the watch and press gently on the case back to close. For screw-back cases, use the screwdriver blade or case-back wrench to turn the slots clockwise, thereby closing the case shut.
Feb 06, 2011 | Bulova Watch
How do you open the back of a movado watch
It could require several tools.
If it is a screw down back you will need a case-back opener (sold at Harbor Freight for $2.99). It is adjustable to fit most case backs. Make sure the wrench fits the notches on the back and rotate counter-clockwise
If it is a snap on case use a knife type case back opener.
Look for a small indention on the case-back that allows you to snap the back off. (some watches have the indention, some do not)
You need to be very careful not to scratch the back
You may need a case-back press to put the snap case back on. Some you can snap on with your fingers other will require the press.
Aug 01, 2010 | Watches
Can;t open back of watchto find date it was made do i need special tool or some thing else can be used
You definitely need special Rolex case back opener. Without it your watch will be locked forever. Rolex cases are so tight, that even when special opener is used, you will need quite strong arms to open it. Rolex case openers sometimes sells on ebay, but they are never cheap.
Jan 07, 2010 | Rolex Daytona 116520 Wrist Watch
Faux men's rolex date just
An authentic Rolex will have a screw down back with exactly 144 small teeth. You can only open a Rolex case with a special Rolex tool (Key). We use the Bergeon hand wrench to open Rolex cases. Supplied with 6 Bergeon grooved chucks(18.50, 20.20, 22.50, 26.50, 28.30 and 29.50 mm), these are the same chuck used in the Bergeon 5700RO and will fit in the Bergeon Bit Adpater for 5700-Z Case Opener our number FB-231. Replacement chucks and replacement handle are available in case you have a set that is missing a piece. As is the case with any fine mechanical instrument, special tools are required in order to properly service and adjust a precision instrument such as a fine timepiece. If you are not experienced, it is better to leave this to a Certified Rolex tech. If you do feel you want to proceed, this tool will set you back about $140.00 or so. Just as the internal parts of the Rolex are exact, so is the watch case that protect the valuable watch movement. These tools are used to open the Rolex case without causing expensive damage. You can call Bob Frei at 510-832-0355 ext. 2 from 11 AM to 5 PM Pacific Time Zone, to order one if you wish, or several other sellers of these fine tools can be found by doing a little research on the net. Hope this has helped you.
Jan 28, 2008 | Rolex Day-Date President 118239 Wristwatch
My memovox is running too fast got it now for about a month
Your question was cut off please explain your problem further Don
Jul 01, 2007 | Jaeger-lecoultre Master Compressor Memovox...
Jaeger-lecoultre Master Compressor Memovox 1708170 Wrist Watch Logo
108 people viewed this question
Top Jaeger-lecoultre Watches Experts
Arturs Kalnins
Arturs Kalnins
Marvin
Marvin
Are you a Jaeger-lecoultre Watch Expert? Answer questions, earn points and help others
