How do I program a Panasonic TA824 to be on an outside line instead of the intercom?
SOURCE: KX-TA824 Select idle CO line
No. C.O. Line group access is always from high to low. However, you can turn off CO 5&6. In programming command 400.
Carl
SOURCE: panasonic kx-t7330 suddenly cannot use intercom and phone calls
I'm guessing the phone is 8 years old and you spilled something into the keystrip.
Start by unplugging it to see if it resets. Then, look for a mechanical failure (sticky buttons, broken buttons, etc.). Some alcohol and a Q-Tip will clean the buttons, or carefully take the phone apart and wash out the housing.
Last, but not least, any of the new 7730/31/35/36 phones will replace that set.
Carl
SOURCE: Cannot activate auto attendant on the Panasonic KX-TA824 phone system
For anyone looking for an answer, it is covered in more detail here
http://members4.boardhost.com/ablecomm/msg/1240472611.html
Carl
SOURCE: I only want my Panasonic KX-T7453 desk phone to ring when, . . .
press the mode button 5 times and then use the jog dial to get the * down to nothing.
your phone should no longer ring.
SOURCE: Want to pick up phone and get an outside line
Yes, put your lines in a line pool, then have your phone automaticly go to Line Pool: <Whatever Pool # you picked, 1 thru 3>
When the storm hit, some of your CO service lines were cutt off.Now when you try to cease an idle line.The system tries to pick a line that was previously available but it now cut off.To prove that, pull out the Plugs put in CO ports of the KX-TA824 and plug in a phone to see if you get a tone.Note the CO Line ports in which they were put.Turn off thr lines in the CO Settings that that have no connection.
