Panasonic TC-26LX20 26 in. HD-Ready LCD Television Logo
Posted on Aug 16, 2007
2005 Panasonic LCD TV Model# TC-26LX20
There is a black/gray, 1 inch thick horizontal line that runs from the middle of the right edge of screen almost to the left edge. It tapers to about 1/2 inch about the middle (or center) of the screen and continues on. Only not apparent when whatever is on that portion of the screen is very dark. I paid $1800 for this TV and I hope this is easily, inexpensively rectified. Cable company (RCN) recalled/replaced an old cable box a few months ago because of "universal" problems -- details of which I do not know. TV was on shelf above that and is now on shelf above much smaller, replacement cable box Shelf below that holds my Panasonic DVD/VCR (although a Samsung DVD/VCR use to be on that shelf.) Bottom shelf holds my wireless router (Linksys) box connected also by the cable company.
  • 1 more comment
  • Anonymous Nov 25, 2007
    mine has the same creeping up from the bottom as well.
  • Anonymous Apr 18, 2008
    I am having the same problem with my TV with the same model number. Dark lines that start at the right side and narrow to a point as they go left across the screen. The lines are mainly visible in dark scenes but it is getting more prominent. I'm assuming it is a problem with the back light but not sure. I was fishing around to see if someone had found out what this is but nothing yet.
  • Anonymous Nov 16, 2008
    I purchased my TV Feb of 2005... noticed the same creeping dark "cloud" about a year and a half ago .. started on the right side 1/3 of the way down from the top. It has since stretched across the TV and now almost touches the left side. Paid $1500 for it .. recently decided to shop for a new TV as the prices have come down.. called Panasonic 877-958-4372 to inquire if there was any kind of known defect with this model. Though they were very nice they actually said "this is the 1st complaint of this type we have received and with all the sets manufactured it is expected that there will be a very small percentage with defects". Though this is a reality I was kinda shocked to get that kind of response - like "oh well, whatever"... I am now looking to buy a TV other than a Panasonic and will be putting this one out to the curb.
A
Anonymous
I am also having problems with the same year and model number panasonic, it is at the repair shop now. I think it is a lemon tv. won't buy panasonics anymore. Tried all the fixes recommended by panasonic. It happens after the tv is on for longer than 1/2 hour. It happens with dvds and different hook ups. my samsung is fine on all the same connections.
Screen issue with Panasonic plasma tv. Model TC-P42S2.
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
1helpful
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
More results from www.cnet.com
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
1helpful
Lightning hit nearby now my Panasonic tc-l3232c has sound but no picture what could be the problem?
Two issues come to mind on LCD/LED TVs with a blank screen. First and foremost, unplug it from the power source for a few minutes, then plug it back in and power on to see if your problem has gone away. If not, then the easiest way to diagnose the problem is to power on your TV in a pitch black room (or drape a thick blanket over it and peek underneath at the screen while it's on)... we want to see if the backlights are working or not. If the screen looks like it's 'lit up' with a dark gray tint to it, then we have backlight and there is another problem. If no backlight, then your set has a bad backlight inverter. In either case, this will require parts replacement. Panasonic is very tight with who they will sell their parts to, unlike other manufacturers and usually require authorization from a technician before selling them.
1helpful
Panasonic tc-l32x2x
I can very well understand how disappointing this is. But no company can ever do a free replacement for such causes. You need to have pest control in the house as the cockroaches can damage any electronic equipment from microwave oven to audio/video equipment in the house. If you do not do that, it will be Panasonic today and some other brand tomorrow.
Panasonic 37 inch lcd tv
Check its back light CCFL lam of that side, which look darker. Replace it.
1helpful
Black screen with colored vertical lines
YPU HAVE A BAD PANEL. THE COST OF REPAIR WILL PROBABLY EXCEED THE VALUE OF THE SET.
Vertical gray stripe on left edge, all pics and text gave a blur
any vertical or horizontal line (any color any size) showing stable on the screen that is the hardware damage at the LCD panel back board ( call panel driver board) . it repair complicate but easy to do change LCD panel (common parts). you need find a PC service dealer to do so.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
