Problem with winodws mobile 5.0 device application
Iam getting this error when i debug my application with windows mobile v4.00.20.0027 GPRS
Native exception has occured in SBT.exe details Exception code:0xc0000005 Exception address: 0x78681e60 reading:0x00000000
when i made smart device CAB and installed in device it throws error : File or assembly name 'Intermec.DataCollection.CF2, one of it's dependencies, was not found.
plz can any one help me to solve this problem
anyone can help me on this plzNo this link didn't help me..
My requirment is, i want to capture image snap shot & save it to directory from my custom built application,
the code which i used is
Re: problem with winodws mobile 5.0 device application
Hi
As far as judgement goes i have given the cause and the solution. Try these steps out and let me know please so that i can solve this issue if there is a bottleneck
Debugging an application involves building the application in debug mode (iOS or Android) and launching the application in an iOS or Android emulator or device. You can then use the Google Chrome debugger to debug the application.
Control Panel / Administrative Tools / Event Manager
Windows 10 in startup apps go to Administrative Tools / Event Manager
Right Click start menu click event Viewer
once there look to left and expand WIndows Logs Click on Applications and wait for them to load See my pictures i found an error then I clicked on it and it told me what app.
If you don't have event viewer turned on you won't get anything. Then just google turn on event viewer your OS = (winodws 10, Windows 8 etc. turn it on reboot once the error occurs it is recorded go to event viewer and see results.
Hi
try this
r all:
*#06# Show IMEI
*#9999# Show mobile Software Version
*#0837# Show mobile Software Version (instructions)
*#0001# Show Serial Parameters
*#9125# Activates the smiley when charging
*#0523# LCD Contrast
*#9998*228# Battery status (capacity, voltage, temperature)
*#9998*246# Program status
*#9998*289# Change Alarm Buzzer Frequency
*#9998*324# Debug Screens
*#9998*364# Watchdog
*#9998*377# EEPROM Error Stack - Use side keys to select values
*#9998*427# Trace Watchdog
*#9998*523# Change LCD contrast
*#9998*544# Jig detect
*#9998*636# Memory status
*#9998*746# SIM File Size
*#9998*778# SIM Service Table
*#9998*785# RTK (Run Time Kernel) errors - if ok then phn is reset, info is put in memory error
*#9998*786# Run, Last UP, Last DOWN
*#9998*837# Mobile Software Version
*#9998*842# Test ******** - Flash the screenlight during 10 sec and vibration activated
*#9998*862# Vocoder Reg - Normal, Earphone or Carkit
*#9998*872# Diag
*#9998*947# Reset On Fatal Error
*#9998*999# Last/Chk
*#9998*9266# Yann debug screen (Debug Screens?)
*#9998*9999# Software version
*0001*s*f*t# Changes serial parameters (s=?, f=0.1, t=0.1)
*0002*?# unknown Samsung's comand
*0003*?# unknown Samsung's comand
For Mobile phones SGH (R210, T100, A300...)
if Samsung code is in format *#9998*xxx#
try write in this *#0xxx#
SGH-600
SGH-2100
*2767*3855# Full EEPROM Reset (THIS CODE REMMOVES SP-LOCK! but also changes IMEI to 447967-89-400044-0
*2767*2878# Custom EEPROM Reset
Samsung mobile phone codes: Samsung E700
*2767*688# remove USER CODE and SIMLOCK
Samsung mobile phone codes: Samsung V200
Unlocking:
Power on the mobile phone without SIM card and type these codes:
*2767*63342# and press green button
*2767*3855# and press green button
*2767*2878# and press green button
*2767*927# and press green button
*2767*7822573738# press button
Phone will be unlocked, but all trims are reseted !!!
Mobile phone must be fully charged
Samsung mobile phone codes: Samsung S500
Unlocking
*2767*MVT# (*2767*688#) E2P MVT Reset
*#SIMLOCK# (*#7465625#)
I have Micromax Q5 with Reliance GSM. Iam not able to activate the GPRS from this mobile. Can any one help me in this regard. Even in this mobile Opera Mini option also there but while opening this application it showing that "Jar not found" what is this? And how to fix this issues?...... I am trying to fix this issue from 5 days. but Iam failed.... Please give a proper solution to avoid this confusion with this mobile.
Gangu,
you cant activate GPRS. It is done by the service provider. Once they activate the GPRS, they will send to you the settings. If in doubt contact their technical helpline. Contact their helpline to get it activated. Tell them the mobile Make and Model.
private Intermec.DataCollection.Imager capture;
public PhotoCapture(string ChasisID)
InitializeComponent();
chaseNo = ChasisID;
lblPhotoID.Text = ChasisID + ".JPG";
try
capture = new Imager(this.picBox,Imager.PictureResolutionSize.Sixteenth);
capture.VideoRunning = true;
catch (MissingMemberException exp1)
MessageBox.Show(exp1.Message);
catch (Exception exp)
MessageBox.Show(exp.Message);
at capture=new Imager it gives me error.
