Whirlpool AWM9000 Front Load Washer Logo
A
Anonymous Posted on May 26, 2013
Whirpool awm 1500 - Whirlpool AWM9000 Front Load Washer
On the display there is blinking S and F and cycle stops and it's beeping. Once I use rinse cycle sometimes there is some water left inside the machine and it has to be spinned ome more time. Many...
Hello mi_wilk64,
If you still need assistance with this concern, please reach out to us, we have a local rep for you to speak with, here is our link: http://www.whirlpool.eu/
Thank you Whirlpool Social Media
Hi i have whirpool awm 8900 and i have fault f11 what is this?
In your service manual it states for the f11 code
F/11 Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
globul1a.gif Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU) globul1a.gif Check the Drive system for any worn or failed components globul1a.gif Check MCU globul1a.gif Check CCU globul1a.gif Check Motor globul1a.gif Check Wire Harness
If you have any further questions message me back I await your reply Thanks again Rick
2helpful
Whirpool awm 8125 overflow failure F09
In the service manual, F09 refers to the pressure switch (pressostat).
In fact, the causes may be all that can fool the control unit.
To fix F09, the unit must be inspected by someone who has the minimum knowledge of how the washing machines work.
Whoever claims this error must be willing to investigate and provide the required details.
2answers
Whirpoll AWM 6000 does not take water.
What to check next is the water inlet valve. To do it, turn on the machine and start the filling cycle. If you cannot hear a faint buzzing or humming noise from the water inlet valve, the solenoid coil is not getting any power. Check it's wiring. If you can hear some noise, you need to replace it. Make sure to unplug the unit before doing any service.
Draining water from washing machine
Filter is normally down r/h side of machine it unscrews anti clockwise..Good luck
No hot water whirpool awm 321/3
A faulty inlet valve solenoid on the hot water side could be the cause. The solenoids can be tested for continuity using a multimeter or ohm meter. A lack of continuity indicates a faulty solenoid. I am attaching a photo for reference purposes. Hope this helps and best wishes.
Need to replace dispenser unit in whirlpool awm 336
OK, solved it now, you need to remove the front instrument panel first. This is held in place by four plastic lugs, two top and two bottom, which you can see when you remove the top of the machine. It's a bit fiddly since you don't want to break the lugs but a bit of patience gets it off clean. Next remove the two pipes that supply hot and cold water from the rear of the dispenser and also another pipe which fits onto the side. There are three small nuts to remove that secure the unit to the front of the machine and then by pushing it backwards and too the side it will slide out easily. Lastly there is a pipe to remove underneath the unit and then it is clear. Simply reverse the process to fit a new unit.
All the best
David
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
