MP3 Shuffle I've loaded up my shuffle with my tunes but it's repeating the same song over and over again until I manually move it forward. How do I get it to automatically go to the next song?
If you set the play mode to shuffle. It should shuffle whatever you are playing, be it All Music, An album or a playlist.
you can set the player to shuffle by pressing the "M" button. from the menu choose "Repeat" mode press "Previous/Next" to scroll through the options until you get to "shuffle". [Press "Play/Pause" to confirm and press M to return to sub menu.
Hey press the play pause button and the enter button at the same time if it has a lock move it baca and forte 6 times while holding play pause button and enter/centered button for 6 seconds, that should solve from freezing ipods to non functioning well :)
You've accidentally turned on "repeat" or "repeat 1" mode. If it has a "mode" key then press it until you cycle through "repeat all" and/or "shuffle" and/or "shuffle repeat" until it says nothing. If you have a cheaper player, the "play mode" function may be hidden in a menu somewhere, to save the physical button. Check around in the menu/settings to see if you can find it, or, in the last resort, check the manual.
Hold Down The M (Menu button) Scroll down to settings, select play mode. Exit out of he menu, press the user button until the squiggly cross with the A appears. Whalaaa you're in shuffle Mode. I hope this was a detailed solution.
ipod shuffle will sync the same songs over and over
Stated above... No matter what settings I use the ipod plays the same song over and over again until I change it manually..
same as his
