SOURCE: my unit has a ton
I would let the managment know about the mold problem, this can be serious. If you want to clean this yourself, use rubber gloves, a brush, and buy a spray bottle of mold remover. The filter should be located behind the front grill. It should snap loose, and they are normally made of a foam material that you can wash in your sink and let dry. Sometimes they remove them a throw them out!! If this is the case, let them no about that also.Please keep me posted.
Shastalaker7
A/C, & Heating Contractor
SOURCE: Clean Filter
Good Afternoon Kate - Thank you for your question! Some air conditioner filters are removed by sliding out from the right-hand side. Others, you need to push the vent handle to the Vent Closed position and open the front panel. Grasp the filter by center and pull up and out the filter can be wash using liquid dishwashing detergent and warm water. Rinse filter thoroughly. Gently shake excess water from the filter. Be sure filter is thoroughly dry before replacing. Keep in mind that instead of washing you may vacuum the filter clean as well. Hope this helps!
