I have a problem with the simplest configuration:
It seems that ur PC & cable modem configuration is ok, now the problem is with ur router WAN interface configuration. the problem would be one out of 2 - first to check whether ur router wan interface is configured properly to obtain IP address from DHCP (if possible, u can give the static ip address with same series as cable modem) second to check with ur ISP.
SOURCE: My TEW-432BRP doesn't work when loggin yahoo mail or microsoft update web!
what are the setting on the router and or pc and modem? Do you have any firewall or portforwarding turned on? Are you using DHCP?
Need more info...
SOURCE: how can I set up a speed stream 4100 modem/router
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. here are the steps u need to do:
1. press the reset button on the back of the trendnet router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the trendnet router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe. Im sure if the computer is connected to the speed stream 4100 modem router you can have an internet access. just in case u did a pppoe settings on the trendnet router and ur done setting the router, u did the connection, then u dont have an internet, set the speedstream modem router to bridge mode
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
if you have any querry pls feel free to get in touch.. good luck
SOURCE: How do I configure my Trendnet tew-432brp?
Try with http://192.168.1.1 or http://192.168.0.1
I hope that this has been very helpful for you
clarification: my ISP is cable TV provider in Israel. Now, very important detail is that another Router ( I tested Netgear) obtains IP address with no problem at all (of course ISP is the same)
Thank you, "jsbasrao", for your concern.
Of course I double checked the router's WAN configuration before I posted the problem and I must confirm that everything seems correct. I could show here the appropriate configuration screens, however I assure that the router is set for automatic IP acquiring.
I still hope that somebody has faced such problem with this specific router model.
Thanks a lot
Who is your cable provider?
