most motor homes tap into the chassis wiring harness so get a workshop manual of the vehicle and the wiring diagrams will be in there
the basic chassis will be a Ford , chev, mercedies , renault etc so the relevant work shop manual will the year and make as shown on the compliance plate
The Easiest Way is to Get the Wiring Harness Diagram with the Colors and Verify that you plugged the Fog Lights into the Correct Harness. I once had a FORD that had a Fuse BOX that had a FOG LIGHT and No Power to that Fuse.
Make sure you test the Fuse at the Box and then Trace the wires and if the Switch was wired at the Factory, you should be all set
Hi there: According with the diagram on 2004 Toyota Camry Car Radio Wiring Diagram...
Car Radio Battery Constant 12v+ Wire: Blue/Yellow Car Radio Accessory Switched 12v+ Wire: Gray Car Radio Ground Wire: Brown Car Radio Illumination Wire: Green Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger Wire: N/A Car Stereo Amp Trigger Wire: Pink/Blue Car Stereo Amplifier Location: Located to the right of the glovebox behind the passenger side of the dash. Car Audio Front Speakers Size: N/A Car Audio Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Pink Left Front Speaker Negative Wire (-): Violet Left Front Tweeter: Powered by the same wires as the left front speaker. Right Front Speaker Positive Wire (+): Light Green Right Front Speaker Negative Wire (-): Blue Right Front Tweeter: Powered by the same wires as the right front speaker. Car Audio Rear Speakers Size: N/A Car Audio Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): Black Left Rear Speaker Negative Wire (-): Yellow Right Rear Speaker Positive Wire (+): Red Right Rear Speaker Negative Wire (-): White
Tehy could be harnesses 15 or 20 pins, try to look your right replacement in this links:
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Go to Autozone.com and register your truck for FREE. Then you can get access to Chassis wiring diagrams and fusebox layouts. The plastic cover on your trailer plug will have the id for each pin in the plug.
The factory chassis diagram should show the fuse providing power to the individual post on the plug.
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not
provide a switched power source. Run a wire to the fusebox or ignition
switch harness for switched power.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
1995 Nissan Sentra Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink Car Radio Switched 12v+ Wire: Blue Car Radio Ground Wire: Chassis Car Radio Illumination Wire: Red/Blue Car Stereo Dimmer Wire: Red/Yellow Car Stereo Antenna Trigger: N/A Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Front Speakers Size: N/A Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Pink Left Front Speaker Negative Wire (-): Blue Right Front Speaker Positive Wire (+): White Right Front Speaker Negative Wire (-): Black Rear Speakers Size: N/A Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): Light Green Left Rear Speaker Negative Wire (-): Violet Right Rear Speaker Positive Wire (+): Blue Right Rear Speaker Negative Wire (-): Pink
I believe you can look up the manufacturer of the trailer plug kit and find the wiring diagram there. On alot of the trailer plug kits, they have pics and diagrams in the package. The 7 pin plug (truck side) is available with the pig tail set up that plugs directly into the wiring harness for the lights. Then all you would have to worry about is the 2 wires for the electric brakes.
1996 Ford Explorer Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Green/Violet Car Radio Switched 12v+ Wire: Yellow/Black Car Radio Ground Wire: Black/Light Green Car Radio Illumination Wire: Light Blue/Red Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger: Orange/Blue Car Stereo Amp Trigger Wire: Blue (If Equipped) Car Stereo Amplifier Location: N/A Front Speakers Size: N/A Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Orange/Light Green Left Front Speaker Negative Wire (-): Light Blue/White Right Front Speaker Positive Wire (+): White/Light Green Right Front Speaker Negative Wire (-): Dark Green/Orange Rear Speakers Size: N/A Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): Gray/Light Blue Left Rear Speaker Negative Wire (-): Tan/Yellow Right Rear Speaker Positive Wire (+): Orange/Red Right Rear Speaker Negative Wire (-): Brown/Pink
