Is there a more detailed step by step for the do it your self installer? I am starting a bathroom project in my unfinished basement. I do plan on hiring a plumber and elec pros. I plan on a deck mount and was wondering were is the place to locate the service panel.
Generally I will make the entire front skirt of the tub removable. You need to make sure your access is located so that you can remove the pump if necessary.
Access to the plumbing is advisable also but usually not required by code as it can be serviced from the top side. I am a licensed bath contractor and available to help with any problem you may encounter through premium service or live chat. I can save you many hours of frustration and 100's of dollars on this project.
