It sounds like your ignitor malfunctioned. You might need to replace it. It's possible to do it yourself, without calling a repairman. Try checking how to do so in the user manual:
Frigidaire gas oven manual
Your oven valve won't open all the way
The ignitor is not working right and is going bad....
have
the repair man replace the ignitor, or DIY....
Check out this tip
about your problem...
Oven not Working or Oven
not Heating
Oven
Problems Replacing
the Igniter
heatman101
I HAVE A GAS RANGE 3 YEARS OLD,FRIGIDAIRE
WHEN OPEN THE DOOR IT MAKES A LOT OF NOISE,
AND WHEN I CLOSE IT DOES NOT CLOSE COMPLETLY
CANT YOU HELP ME,THANG YOU
I'm having the exact same problem. I checked the wires to the oven valve and they seem fine.
I'm having the same problem with my Frigidaire oven. The ignitor comes on but the gas valve doesn't always open. If you turn it off and on a few times eventually it will come on. There is an odor of gas as if some gas came out but not enough to ignite.
Same problem, turn oven on, I smell gas and the oven just gets warm, not hot...the Top burners work but the oven itself will not come on.
Can someone tell me if I can fix this myself?
Smell gas oven won't turn on.
the ignitor comes on but no flame
