I want to fix an HDMI Overscan. I called Sanyo customer service but they had no idea what I was talking about.. I have tried pluging in the TV while pressing Volume Down (The TV does not turn on) Channel Down (Same problem, it still wont turn on) Any other ways or more specific instructions would help me a lot. Sanyo Model DP42410
Press the volume + and channel - buttons at the same time for about 5 seconds. It must make it into service mode. But, what are you intended to do after entering this mode? There will be a special screen display, that will not resemble to normal user menu. Any data value set here should be changed very carefully. Improper data setting to this mode, might even make TV iresponsive to any external signals, means, the TV has gone for ever. If you do not know anything about this mode, and adjustments, never enter into it. Let it do by any experienced service technician. For more procedure to get into service mode and to make adjustments, check this link, if you wish.http://electronicshelponline.blogspot.com/
Testimonial: "I tried and it didnt work, here are the steps I followed: 1.Turned off the TV 2.Unplugged the TV 3. Pressed down both Vol+ and Ch- buttons (On the TV not the remote) while plugging in the TV for 5 seconds Nothing happened, also tried: 1.Turned on the TV 2.Pressed Vol+ and Ch- (On the TV not the remote) at the same time for 5 seconds Still nothing :( I just want to see if I can disable the HDMI overscan I will ignore all other settings. If I get in there and its something I cant handle I wont change anything and just exit the Service menu."
