Vertical green stripe with skype doest not go away, tried everything! (Upgrading and downgrading!) Running Vista 64bit Ultimate Creative Live Cam Optia AF!
You can use either T 568 A or B providing that both ends of the cable are wired in the same format. If one side is allready ended thenI would try T568 B standard first.
Pin
T568A Pair
T568B Pair
Wire
T568A Color
T568B Color
Pins on plug face (socket is reversed)
tip
white/green stripe
white/orange stripe
ring
green solid
orange solid
tip
white/orange stripe
white/green stripe
ring
blue solid
blue solid
5
tip
white/blue stripe
white/blue stripe
6
ring
orange solid
green solid
7
tip
white/brown stripe
white/brown stripe
8
ring
brown solid
Side 1 Side 2 White Orange White Orange Orange Orange White green White Green Blue Blue White Blue White Blue Green Green White Brown White Brown Brown Brown
Cross Cabling :
Side 1 Side 2 White Orange White Green Orange Green White Green White Orange Blue Blue White Blue White Blue Green Orange White Brown White Brown Brown Brown
Hope this helps. Please rate my response. Thanks. Have a good day.
Hot at all times from CJB Fuse #1 is pin #9, light green w/ violet stripe wire Hot in start from CJB Fuse #20 is pin 3, Red w/ black stripe wire Hot in Accessory or run from CJB Fuse #8 is pin 10, Black w/ Pink stripe wire.
Grounds in the connector : pin 2, black pin 11 black w/ light green stripe pin 16 black w/ light green stripe. pin #1 light blue w/ red stripe is the instrument illumination, after the cluster dimmer switch.
I would stay away from using the black w/ light green stripe, I seem to recall those are the shields for the speaker pairs.
Bit late on the reply, just caught this one. If you don't have it don't, good luck
Hi, The black vertical line is caused by a leaking capacitor, Check and replace poped capacitor with a new won and it will work fine again. No worries. Thanks for using fixya.
A Right Rear Spkr (-) Dark Brown w/ Pink Stripe Purple w/ Black Stripe
B Right Rear Spkr (+) Tan w/ Green Stripe Purple
C Right Front Spkr (-) Green w/ Orange Stripe Gray w/ Black Stripe
D Right Front Spkr (+) White / Green Stripe Gray
E Left Rear Spkr (-) Tan w/ Yellow Stripe Green w/ Black Stripe
F Left Rear Spkr (+) Tan w/ White Stripe Green
G Left Front Spkr (-) Lite Blue w/ White Stripe White w/ Black Stripe
H Left Front Spkr (+) Orange w/ Green Stripe White
I Amplifier Turn On Do Not Use For This Vehicle
J Power Antenna Turn On Do Not Use For This Vehicle
K Ground Wire Black w/ Green Stripe Black
L Do Not Use For This Vehicle
M Dash Light Dimmer Wire Orange (if available)
N +12 Volt Ignition Wire Thin Black Wire Red
O Do Not Use For This Vehicle
P +12 Volt Battery Wire Green w/ Black Stripe Yellow
Normal
0
See section A. Skype in the info below to setup the Audio & Video. Also send this to your family
and friends so they have their computer setup properly. Web Camera’s have to be
setup on the program they are to be used with.Just installing the camera on your computer does not set it up to
broadcast on messengers or Skype.
Each program has Options that have to be setup in order for
the Audio and Video to function properly. A.Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/)
set it up as follows:
Go to Tools,
then Options, and click on Audio Settings and set the Microphone
and Speakers to the computer Audio Card.
Then
click on the Video Settings.
The
camera if Installed Properly will come up and show a video picture.
Then,
on the bottom of the page click on Save.
The camera and audio should function properly.Your friends and Family will now be able to
see and her to you. B.Yahoo Setup:
After downloading and installing Yahoo Messenger(http://ca.messenger.yahoo.com/download/
) set it up as follows:
Click
on Messenger at the top left and then go down to Preferences
and then the Preference Window will come up.
Next
click on Calling and Devices. In the Calling & Devices
on the right and set the Microphone and Speakers to the computer
Audio Card or sound device installed in the computer.
Just
below that, go to the Test Audio section and(in blue writing) click on“Open the call setup assistant”
and follow the instructions on the left window.
Then
after completing the Audio Setup, go to down and click on Webcam it
should BRODCSAST and you will see your picture.
To
Chat, click on MESSENGER and then
After
make necessary settings, click on APPLY, then OK.
Then
click on MESSENGER and go to my WEBCAMready to use.
I can think of two possibilities. The hardware is not working porperly, or the camera's physical connection the the computer is not completely working. Try reinstalling the drivers and plug the camera into a different port. If that does not work, my next guess is the manufacture process of that camera is shotty and some of them do not work properly, I would exchange mine with a warranty if possible.
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe Car Radio Ground Wire = Black Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe Car Radio Dimmer Wire = Light Blue w/ Red Stripe Car Radio Illumination Wire = Orange w/ Black Stripe ?? Don't know ?? Red Wire (No power to wire Constant or Accessory) Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front: White w/ Green Stripe (+) Brown (no stripe) (-)
Right Rear: Purple w/ White Stripe (+) Light Blue (no stripe) (-)
Left Front: Light Green (no stripe) (+) White w/ Orange Stripe (-)
Left Rear: Light Blue w/ Black Stripe (+) Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front: White w/ Green Stripe (+) Green w/ Orange Stripe (-)
Right Rear: Orange w/ Red Stripe (+) Black w/ White Stripe (-)
Left Front: Orange w/ Green Stripe (+) Blue w/ White Stripe (-)
Left Rear: Red w/ Green Stripe (+) Red w/ Blue Stripe (-)
Hope this helps. I spent hours looking for the correct color key and this one works for my '91 Explorer.
You didn't cut the plastic connectors off the factory wiring, did you? One is gray and one black.... if not, just get to a stereo shop and buy a wiring kit for your car and all colors will match. They're about $10.
If you DID..... well.....
we have a LOT of work to do....
