Question about Lanier 1205 Copier
Lanier 7320 error message c-41 can someone tell me whats wrong
Need help with error message c-41 lanier 7320
    Novelist:
  • 158 Answers
I believe c-41 is a fuser problem. A trained copier tech may be required to troubleshoot.
Posted on Apr 29, 2009
SOURCE:
Printer isnt working properly
Yes people do, its a Ricoh box call your local Ricoh dealer, and they/we do service these, your problem is a hot section error.
Mar 12, 2014 | Lanier LD533C Magenta Toner Cartridge...
Very light copy in 2nd side copy
its a moisture issue in the paper. try nice new dry paper and i bet it works fine
Mar 17, 2012 | Lanier Office Equipment & Supplies
I have a black line on my copies. i have a lanier 7320 copier. Is it my drum?
It could likely be the drum. Is the line on copies and prints, or just copies? If it's just on copies, it's not the drum.
Jan 18, 2011 | Lanier 1205 Copier
I have a lanier 7328/7320. It reads side door open on screen. Only the door is closed. Any suggestions
How are you? This is a problem with front door switch.
Remedy
  • Place the machine on a level table and make sure all the four stands are landing freely on this table.
  • Check that the front door notch that closes the door switch is not broken and if it is replace that particular door or modify the notch.
  • Make sure the upper half of copier is well locked with the lower bottom part.
If all the above is correct, and still reads open, replace the door switch.
Good luck.
Nov 15, 2010 | Lanier Office Equipment & Supplies
Lanier Model #7320 Copier SN 826255. Has a wrench
Press "clear/stop" and "8" at the same time. An error code will be displayed in the copy quantity window as long as those two button are held down. What is the error code? Each code is specific to different areas of the copier. I will be more than happy to assist you in resolving.
Sep 23, 2009 | Lanier Office Equipment & Supplies
Lanier 7320 - Makes only all black copies
Was the toner bottle removed before you moved the machine?
Jun 09, 2008 | Office Equipment & Supplies
Printer problem
You need service on your copier. It might just need a cleaning, or possibly a part. If they are random spots on your copies, then there is a good chance the cleaning unit seal needs to be replaced.
Jan 24, 2008 | Office Equipment & Supplies
Machine Error 41
Error code 41, Print cartridge is bad and gone out. Needs to be replaced by authorize dealer for just under $100.00 ($55.00 part & $40.00 Labor).
Nov 14, 2006 | Brother IntelliFAX 1800C All-In-One...
312 people viewed this question
Top Lanier Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
gggg
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
