I recently got a vcr/dvd combo unit and it is new. apparently this new one does not come with a tv tuner or a coaxial input so i simply can not record tv which is what i want to do. the book even says i need an external tuner to record tv broadcasts. what exactly is this ''external tuner''? is it a digital-to-analog converter box? i need help on what i need to buy and what connections i need to do. also on a side note, i get cable on my tv from the wire on the wall. after Feb 17. nothing has changed so i guess i already had digital tv meaning i dont need to get a converter box to watch tv? do i have to get a converter box JUST to record from my vcr with no tv tuner?
I would need your exact model # to get very specific, but in general:
The "External tuner" will need to come from your TV or a cable/sat box, generally. If your TV has a Video OUT or a Monitor OUT (most television don't), you can hook a yellow AV/RCA video cable from the TV to the Magnavox. You will also need to hook a red/white audio cable from the Audio OUT of your TV to the Magnavox.
Your TV probably doesn't have a Video OUT, so you will need to buy a box. A digital cable box for your cable service would be the best investment. Alternatively, if you can find a digital-to-analog converter box (but these are iffy). Once you have one of these box types, you will need to hook a red, white, and yellow AV/RCA cable from the video/audio OUT of the box to an available video/audio in on your television.
Once your connections are correct, the general rule with tuner-less recorders is: If you can see the channel that you want to record on the television screen, then you will be able to record it.
One final note about Feb 17, 2009: Thanks to Congress, the digital transition date was moved to June 12, 2009 - many areas have already switched, but there is at least a chance that you are in an area that hasn't switched yet.
Let me know the exact model # of your television, and I can tell you if it has a video/monitor out - or, let me know what type of box you decide to buy.
-Tha Mp3 Doctor
thanx thats alot of help. i checked and i know my tv does not have video/monitor out. i am kinda of iffy about buying a box though if it is even worth it. i just wanted to record one tv show.
MY TV IS A NEW RCA FLAT SCREEN: MODEL L32HD31YX13. MY MAGNAVOX DVD/VHS RECORDER'S MODEL ZV420MW8. CAN YOU GIVE ME MORE DETAILS?
