Question about Hotpoint-Ariston FDD914 24 in. Built-in Dishwasher
Dtergent dispencer does not open
Detergent dispencer does not open during wash cycle. is this opened mechanically ie by a jet of water or electronically opened
    Top Expert:
  • Hotpoint-Ari... Master
  • 12,223 Answers
Dispenser Lever
If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replaced.
Detergent Dispenser Cover
If the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
Wax Motor Actuator
If the dispenser will not release the detergent the actuator connected between the wax motor and the dispenser might be broken. Check the wax motor actuator and replace it if necessary.
Detergent Container
If the dishwasher dispenser doesn't work the detergent container may need to be replaced.
Dispenser Lid
If the dispenser is broken and doesn't open or close properly the dispenser lid may have to be replaced.
Detergent Dispenser
If the dishwasher dispenser doesn't work the problem is often related to the release mechanism. If the problem is with the dispenser itself, it may be easier to replace the entire dispenser.
Dispenser Door Spring
If the dispenser is broken and doesn't open during the wash cycle the dispenser door spring may have to be replaced.
Dispenser Latch
If the dispenser is broken and doesn't open or close properly the dispenser door latch may have to be replaced.
Dispenser Door Pin
If the dispenser is broken and doesn't open or close properly the dispenser door pin may have to be replaced.
Enter your model number to see parts for your dishwasher.
Dispenser Actuator
If the dispenser is broken and doesn't open or close properly the dispenser actuator may have to be replaced.
Dispenser
If the dispenser is broken and doesn't open or close properly the entire dispenser assembly may have to be replaced.
Wax Motor
There is an electrically powered device called a wax motor which opens the detergent dispenser. If the dispenser is broken and will not open to release the detergent, the wax motor might need to be replaced.
Bi-Metal
If the dishwasher dispenser doesn't work the bi-metal actuator might be burned out or defective. The bi-metal is a simple metal loop which acts as a latch for the dispenser door. As electricity is applied to the metal loop, the loop deforms and bends away from the latch, releasing it. If the bi-metal is burned out it won't deform or release the detergent door.
Dispenser Slide
If the dispenser is broken and doesn't open or close properly the dispenser slide may need to be replaced.
Dispenser Repair Kit
If the dispenser is broken this dispenser kit may need to be replaced.
Main Control Board
The main control board provides power to nearly every component of the dishwasher including the detergent dispenser. If the dispenser will not actuate the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
God bless you . see the photo attached.dtergent dispencer does not open - 401f2962-5d22-48f3-89be-c1db11d8eabe.jpg
Posted on May 24, 2013
  • Daniel vierra
    Daniel vierra Mar 28, 2014
    Not a good explanation at all there is ways to trouble shoot where the actual problem is by testing by ohms or continuity
SOURCE:
The dispenser door is stuck in the closed position. No matter how much I try to jiggle it open the door will not slide out. How do I get the door to open without breaking something?
Hi stuwstark, you could try running a quick wash cyle without any clothes in the tub once cycle is activated you will hear water flowing through the dispencer holder from there you can try riggling the dispencer to see if it will loosen up, in some cases the dispencer holder can become stuck due to dry soap powder clogging up the sliding rails also the dispencer holder can become stuck due to the liquid detergent box "insert" becoming loose and jamming it self up against the top casing of the dispencer holder so by applying the cycle when the water flushes thru the holder could ease the hard powder or could float the insert making it easier to open,try it and see how you go, thumbs up if it helps thanks.
May 06, 2011 | LG WM-2277HW Front Load Washer
Thanks for your help. I have a Kenmore Model # 66513782K600 the main soap dispencer did not open during wash cycle can you steer me down the right path to complete repairs. Thanks again Ken.
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Apr 24, 2011 | Dishwashers
Dishwasher detergent door will not open during wash cycle
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
heatman101
Feb 23, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
I have a 13 year old Maytag that works great. But recently the flipper door that dispences the dry detergent doesn't open during the wash cycle. I've tried cleaning it thoroughly, but that hasn't made a...
heatman101
Sep 17, 2010 | Maytag 24 in. MDB6600A Jetclean II...
The dishwater detergent dispencer doesn't open when it should during it's timing cycle.
HI, this is the result of a damaged Actuator assembly. you will need to replace this assembly. it is a spring loaded assembly that dispenses the detergent.
It is damaged. Replace your
Actuator assembly for detergent dispenser
Jun 01, 2009 | Roper 24 in. RUD3000 Built-in Dishwasher
Water pouring from detergent, bleach, etc.. dispencer. Help!
This is joyce
He is right the Jets are probl stoped up with mold,
you need to take drawer out look to top of machine where water comes into drawer to dispense to your detergetnt, and see if their is mold, if so take squirt bottel full of bleach and squirt it up on the mold and let sit a while and then take tooth brush and scrub off as good as possible, run one cup bleach in machine with out any clothes . on hot cycle. do this 2 times see if this helps .
let me know. it can only help cant hurt.
willl make machine smell better, and never shut door to front loader completly shut, it needs air to dry or else it will mold.
thanks
joyce
Feb 11, 2009 | Maytag MAH8700A Front Load Washer
The fabric softner drains out as soon as I pour it in
the fabric softner drains or flushs down in the rinse cycles,,,now if you fill past the line or open in dispencer it will sphion down by it self,,in short your overfilling dispencers,,onthejob
Jan 07, 2009 | Kenmore Elite 45986 Front Load Washer
Dishes don't get clean. soap still on inside of door. . . water coming up to fill line and hot enough and dishwasher drains after cycle, spray arms are clear. . . help!
Water from the wash arms must be able to reach the detergent cup during the wash. It sounds as though the machine may be over-loaded during the wash and water does not cause the detergent to mix with the wash tank water. Try washing a cycle with nothing in the machine. Does the detergent still stick to the door?
If no, the machine is overloaded. Wash fewer items or smaller items so spray will contact detergent.
If yes, you have probably lost wash pressure. Clean all screens and jets.
Hope this helps,
Kermit
Aug 13, 2008 | Dishwashers
LG Tromm 8/4 WD R8012
The manual suggests to shut the water off ,
remove the inlet hose and check the screen for blockage.
The ie message is the inlet water is insufficient.
May 22, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Detergent will not dispense during the wash cycle
Something simple you can check is to make sure the spring that flips open the door is not broken or caked up with detergent.
As for the soap not dissolving, I've had similar problems and the only solution I've found is to make sure you are not blocking  the spray jet on the bottom from hitting the soap drawer.
Oct 26, 2007 | Frigidaire 24 in. FDB635RF Built-in...
Hotpoint-Ariston FDD914 24 in. Built-in Dishwasher Logo
813 people viewed this question
Top Hotpoint-Ariston Dishwashers Experts
Marvin
Marvin
Are you a Hotpoint-Ariston Dishwasher Expert? Answer questions, earn points and help others
